lib_extra_dirs = ~/Documents/Arduino/libraries
This is not a good idea and should be removed.
Only add libraries to your project that are really needed.
Unfortunately I cannot compile your project. I get the following errors:
In file included from src\Default_Robot.cpp:18:
lib\main/PressureSensor.h:30:31: error: unable to find numeric literal operator 'operator""F'
30 | float pressure_cal_slope = -5F;
Compiling .pio\build\teensy40\lib372\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
lib\SD\src\File.cpp: In constructor 'SDLib::File::File(SdFile, const char*)':
lib\SD\src\File.cpp:25:11: warning: 'void* memcpy(void*, const void*, size_t)' writing to an object of type 'class SdFile' with no trivial copy-assignment; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
25 | memcpy(_file, &f, sizeof(SdFile));
In file included from lib\SD\src/SD.h:20,
from lib\SD\src\File.cpp:15:
lib\SD\src/utility/SdFat.h:151:7: note: 'class SdFile' declared here
151 | class SdFile : public Print {
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp: In member function 'char* Adafruit_GPS::build(char*, const char*, const char*, char, bool)':
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:76:10: warning: 'char* strncpy(char*, const char*, size_t)' output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
76 | strncpy(p, thisSource, strlen(thisSource));
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:78:10: warning: 'char* strncpy(char*, const char*, size_t)' output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
78 | strncpy(p, thisSentence, strlen(thisSentence));
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:593:10: warning: 'sprintf' argument 3 overlaps destination object 'nmea' [-Wrestrict]
593 | sprintf(buff, "%s*%02X", buff, cs);
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:68:33: note: destination object referenced by 'restrict'-qualified argument 1 was declared here
68 | char *Adafruit_GPS::build(char *nmea, const char *thisSource,
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:568:12: warning: 'sprintf' argument 3 overlaps destination object 'nmea' [-Wrestrict]
568 | sprintf(nmea, "%s\r\n", nmea);
Compiling .pio\build\teensy40\lib77c\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp.o
*** [.pio\build\teensy40\src\Default_Robot.cpp.o] Error 1
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp: In member function 'void Adafruit_GPS::addChecksum(char*)':
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:593:10: warning: 'sprintf' argument 3 overlaps destination object 'buff' [-Wrestrict]
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_build.cpp:586:38: note: destination object referenced by 'restrict'-qualified argument 1 was declared here
586 | void Adafruit_GPS::addChecksum(char *buff) {
lib\SD\src\utility\SdFile.cpp: In member function 'uint8_t SdFile::open(SdFile*, const char*, uint8_t)':
lib\SD\src\utility\SdFile.cpp:532:15: warning: taking address of packed member of 'directoryEntry' may result in an unaligned pointer value [-Waddress-of-packed-member]
532 | dateTime_(&p->creationDate, &p->creationTime);
lib\SD\src\utility\SdFile.cpp:532:33: warning: taking address of packed member of 'directoryEntry' may result in an unaligned pointer value [-Waddress-of-packed-member]
lib\SD\src\utility\SdFile.cpp: In member function 'uint8_t SdFile::sync(uint8_t)':
lib\SD\src\utility\SdFile.cpp:1155:17: warning: taking address of packed member of 'directoryEntry' may result in an unaligned pointer value [-Waddress-of-packed-member]
1155 | dateTime_(&d->lastWriteDate, &d->lastWriteTime);
lib\SD\src\utility\SdFile.cpp:1155:36: warning: taking address of packed member of 'directoryEntry' may result in an unaligned pointer value [-Waddress-of-packed-member]
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_parse.cpp: In member function 'char* Adafruit_GPS::parseStr(char*, char*, int)':
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_parse.cpp:766:14: warning: 'char* strncpy(char*, const char*, size_t)' specified bound depends on the length of the source argument [-Wstringop-truncation]
766 | strncpy(buff, p, len); // or to the end or max capacity
.pio\libdeps\teensy40\Adafruit GPS Library\src\NMEA_parse.cpp:765:28: note: length computed here
765 | len = min((int)strlen(p), n - 1);
This project seems to be very extensive and contains symbolic links to other repositories in the lib folder.
Can the project be built with the Arduino IDE?
There is a description in the original repository: GitHub - HMC-E80/E80: Files for E80
