I have three files:
main.cpp
#include "test.h"
do_something();
Serial.println(doppelt_definiert);
test.h
#ifndef _test_h_
#define _test_h_
int doppelt_definiert;
void do_something();
test.cpp
#include "test.h"
void do_something(){
doppelt_definiert = 5;
Serial.println("\ndone");
When I compile this, I get this Errors:
* Executing task in folder Linker-Fehler-Test: C:\Users\gerdh\.platformio\penv\Scripts\platformio.exe run
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (4.2.1) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- toolchain-xtensa @ 2.100300.220621 (10.3.0)
Found 39 compatible libraries
Compiling .pio\build\nodemcuv2\src\main.cpp.o
Compiling .pio\build\nodemcuv2\src\test.cpp.o
Linking .pio\build\nodemcuv2\firmware.elf
c:/users/gerdh/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcuv2\src\test.cpp.o:(.bss.doppelt_definiert+0x0): multiple definition
of `doppelt_definiert'; .pio\build\nodemcuv2\src\main.cpp.o:(.bss.doppelt_definiert+0x0): first defined here
*** [.pio\build\nodemcuv2\firmware.elf] Error 1
But: If I do not include test.h in the test.cpp file, I get
src\test.cpp: In function 'void do_something()':
src\test.cpp:4:5: error: 'doppelt_definiert' was not declared in this scope
if I do not include test.h in main.cpp, I get
src\main.cpp: In function 'void loop()':
src\main.cpp:7:3: error: 'do_something' was not declared in this scope
7 | do_something();
src\main.cpp:8:18: error: 'doppelt_definiert' was not declared in this scope
8 | Serial.println(doppelt_definiert);
How I have to fix this, or where I am thinking wrong?
Greetings
Gerd
