Collect2: error: ld returned 1 exit status *** [.pio/build/nodemcuv2/firmware.elf] Error 1
I want to use ESP32 for my app. When I compile this code with PlatformIO I get the following error:
  [env:nodemcuv2]
platform = https://github.com/Jason2866/platform-espressif32.git#feature/arduino-idf-v4.4
board = nodemcu-32s
I get this Error:
    |-- <ESP32 BLE Arduino> 2.0.0
Linking .pio/build/nodemcuv2/firmware.elf
/Users/juliusschmid/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: final link failed: bad value
I don’t understand why I get this error message. Can someone help me and explain easily how I can fix the error?
This is an external, experimental platform using the newest version. As per Support for the latest Arduino v2.0 · Issue #619 · platformio/platform-espressif32 · GitHub, the new Arduino Core 2.0 version (which are based on ESO-IDF v4.x) are not officially supported in PlatformIO yet.
Per the comments in the linked issue it looks like you did not update esptool.py. Try the configuration as shown in Support for the latest Arduino v2.0 · Issue #619 · platformio/platform-espressif32 · GitHub, or wait for official PlatformIO support.
After doing this I get this error:
Is there any solution now or do I have to wait for the support?
