CodeBlocks+ PIO + ESPDIF won't compile. ->Could not find “sdkconfig.json” file
im trying to compile the project in codeblocks, but getting the following error:
PLATFORM: Espressif 32 1.12.3 > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32 160MHz, 320KB RAM, 4MB Flash
 - framework-espidf 3.40001.200521 (4.0.1)
 - tool-cmake 3.16.4
 - tool-ninja 1.7.1
 - toolchain-esp32ulp 1.22851.190618 (2.28.51)
 - toolchain-xtensa32 2.80200.200226 (8.2.0)
Error: Couldn't find the main target of the project!
Warning: Could not find "sdkconfig.json" file
========================== [FAILED] Took 1.59 seconds ==========================
Process terminated with status 1 (0 minute(s), 2 second(s))
1 error(s), 1 warning(s) (0 minute(s), 2 second(s))
The platformio.ini :
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
framework = espidf
	id=246@^2.6.2
	ESPUI
	ESPAsyncWebserver
	64
	ESPAsyncTCP
board_build.f_cpu = 160000000L
should i change the “framework” to “Arduino” - i get the project to compile.
the main.cpp:
 #include <time.h>
#include "sdkconfig.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include <Sensor_DHT.h>
#include <sensor.h>
#include <gui.h>
#include <net.h>
PIO lib list:
[az@dell5000 Proj_arduino]$ ~/.platformio/penv/bin/pio lib list
    Library Storage: /home/az/Work/Arduino/Proj_arduino/.pio/libdeps/esp32doit-devkit-v1
    ArduinoJson
#ID: 64
A simple and efficient JSON library for embedded C++. ArduinoJson supports ✔ serialization, ✔ deserialization, ✔ MessagePack, ✔ fixed allocation, ✔ zero-copy, ✔ streams, ✔ filtering, and more. It is the most popular Arduino library on GitHub ❤❤❤❤❤. Check out arduinojson.org for a comprehensive documentation
Version: 6.15.2
    Homepage: https://arduinojson.org/?utm_source=meta&utm_medium=library.json
    Keywords: web, json, http, rest
    Compatible frameworks: arduino
    Compatible platforms: atmelavr, atmelmegaavr, atmelsam, espressif32, espressif8266, gd32v, infineonxmc, intel_arc32, kendryte210, microchippic32, nordicnrf51, nordicnrf52, ststm32, ststm8, teensy, timsp430
    Authors: Benoit Blanchon
AsyncTCP
#ID: 1826
Asynchronous TCP Library for ESP32
Version: 1.1.1
License: LGPL-3.0
Keywords: async, tcp
Compatible platforms: espressif32
Authors: Hristo Gochkov
ESP Async WebServer
#ID: 306
Asynchronous HTTP and WebSocket Server Library for ESP8266 and ESP32
Version: 1.2.3
License: LGPL-3.0
Keywords: async, websocket, http, webserver
Compatible platforms: espressif32, espressif8266
ESPAsyncTCP
#ID: 305
Asynchronous TCP Library for ESP8266
Version: 1.2.2
License: LGPL-3.0
Compatible platforms: espressif8266
ESPUI
#ID: 1917
ESP32 and ESP8266 Web Interface Library
Version: 2.0.0
Keywords: espressif, web, interface, iot, control, simple, easy, ui, userinterface
Authors: Lukas Bachschwell
RCSwitch
#ID: 246
Use your Arduino or Raspberry Pi to operate remote radio controlled devices
Version: 2.52
Keywords: wireless, rf, radio
Compatible frameworks: energia, wiringpi, arduino
Compatible platforms: atmelavr, atmelsam, espressif8266, intel_arc32, linux_arm, microchippic32, nordicnrf51, teensy, timsp430, titiva
Authors: Suat Ozgur
PlatformIO, version 4.3.4
Please advise.
You have specified that you want to compile for the espidf framewokr but you are including Arduino libraries which are not compatible by default.
ESP-IDF project need to have specific files (CMakeList.txt etc), see platform-espressif32/examples/espidf-blink at develop · platformio/platform-espressif32 · GitHub. Without these, errors occur.
Spot on! Thank you., Maximillian
