I’m using this board
(Actually I’m using V1.0 of that board)
When I compile the source with Arduino and launcht it from there it works fine.
When I take the same sourcecode to PlatformIO and compile it there, I don’t get errors, but the board does nothing. What coulde be going wrong?
Source: (only change is the added ‘#include <Arduino.h>’ line
// Includes
#include <OneWire.h>
#include <DallasTemperature.h>
OneWire oneWire( D4 );
DallasTemperature sensors( &oneWire );
void setup()
// initialize Dallas
pinMode( D7, OUTPUT );
pinMode( D4, INPUT_PULLUP );
pinMode( D3, OUTPUT );
digitalWrite( D7, LOW );
digitalWrite( D3, HIGH );
// initialize LED
pinMode( LED_BUILTIN, OUTPUT );
// Serial
Serial.begin( 115200 );
while( !Serial )
; // wait for serial port to connect. Needed for native USB port only
void loop()
float temp;
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
sensors.requestTemperatures(); // Send the command to get temperature readings
temp = sensors.getTempCByIndex(0);
Serial.println(temp);
Here’s my platformio.ini file:
[env:beetle]
board = firebeetle32
knolleary/PubSubClient@^2.8
bblanchon/ArduinoJson@^6.20.1
paulstoffregen/OneWire@^2.3.7
milesburton/DallasTemperature@^3.11.0
Here are the settings for the project in Arduino
