Code execution time is very slow
Hello everyone, I have a core board of F401CCU6. In the first test, I lighted three rgb leds.
The interval time is 1000ms,.
but after I upload the program, the interval between the two colors is about 2000ms.
This is much slower than in my code.
  #include "Arduino.h"
  int red = 0;
  int green = 1;
  int blue = 2;
  void setup()
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  void loop()
  digitalWrite(red, LOW);
  delay(1000);
  digitalWrite(red, HIGH);
  digitalWrite(green, LOW);
  delay(1000);
  digitalWrite(green, HIGH);
  digitalWrite(blue, LOW);
  delay(1000);
  digitalWrite(blue, HIGH);
Compilation results:
    Processing blackpill_f401cc (platform: ststm32; board: blackpill_f401cc; framework: arduino)
    CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/blackpill_f401cc.html
    PLATFORM: ST STM32 (12.0.0) > BlackPill F401CC
    HARDWARE: STM32F401CCU6 84MHz, 64KB RAM, 256KB Flash
    DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink, stlink)
    - framework-arduinoststm32 4.10900.200819 (1.9.0)
    - framework-cmsis 2.50501.200527 (5.5.1)
    - toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
    Found 18 compatible libraries
    Compiling .pio/build/blackpill_f401cc/src/main.cpp.o
    Linking .pio/build/blackpill_f401cc/firmware.elf
    Building .pio/build/blackpill_f401cc/firmware.bin
    Checking size .pio/build/blackpill_f401cc/firmware.elf
    RAM:   [          ]   1.4% (used 892 bytes from 65536 bytes)
    Flash: [          ]   4.1% (used 10876 bytes from 262144 bytes)
截屏2021-03-16上午12.41.01
截屏2021-03-16上午12.50.11
What text is on the crystal or what does the board manifufacturer say the crystal frequency is? 25 MHz?
It could be wrong clock settings to a wrong final operating frequency of the chip.
Is the behavior the same with board = genericSTM32F401CC in the platformio.ini instead of blackpill_f401cc?
Hey,The crystal is 12mhz.
I also tried to set board = blackpill_f401cc, but the flashing time became faster, about 500ms apart
Can you please use the platformio.ini
[env:genericSTM32F401CC]
platform = ststm32
   -D HSE_VALUE=12000000U
and retry.
OK,thank your suggest.
