New to Arduino and PIO, so forgive me if this is a dumb question.
The code is rather simple. Just lighting up a single-digit 7-segment display,
#include "SevSeg.h"
SevSeg sevseg;
void setup(){
byte numDigits = 1;
byte digitPins[] = {};
byte segmentPins[] = {6, 5, 2, 3, 4, 7, 8, 9};
bool resistorsOnSegments = true;
byte hardwareConfig = COMMON_CATHODE;
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
sevseg.setBrightness(90);
void loop(){
sevseg.setNumber(5);
sevseg.refreshDisplay();
The code compiles with both PIO and Arduino IDE, but only Arduino IDE uploaded one will show a number “5”.
The board is an Arduino Uno 3. Here is a screenshot of the tools
menu.
platformio.ini
is almost default with library SevSeg
added.
[env:uno]
board = uno
lib_deps = deanisme/SevSeg@^3.7.0
Here is the build log, where I don’t see any error.
Processing uno (platform: atmelavr; board: uno; framework: arduino)
Removing unused dependencies...
Library Manager: Installing deanisme/SevSeg @ ^3.7.0
Library Manager: SevSeg@3.7.0 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (4.0.0) > Arduino Uno
- framework-arduino-avr @ 5.1.0
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 6 compatible libraries
|-- SevSeg @ 3.7.0
Compiling .pio\build\uno\src\main.cpp.o
Compiling .pio\build\uno\lib18e\SevSeg\SevSeg.cpp.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\uno\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Print.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\uno\FrameworkArduino\USBCore.cpp.o
Compiling .pio\build\uno\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\uno\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\uno\FrameworkArduino\WString.cpp.o
Compiling .pio\build\uno\FrameworkArduino\abi.cpp.o
Archiving .pio\build\uno\lib18e\libSevSeg.a
Compiling .pio\build\uno\FrameworkArduino\hooks.c.o
Compiling .pio\build\uno\FrameworkArduino\main.cpp.o
Compiling .pio\build\uno\FrameworkArduino\new.cpp.o
Compiling .pio\build\uno\FrameworkArduino\wiring.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\uno\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\uno\libFrameworkArduino.a
Linking .pio\build\uno\firmware.elf
Checking size .pio\build\uno\firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.4% (used 444 bytes from 32256 bytes)
Building .pio\build\uno\firmware.hex
AVAILABLE: arduino
Looking for upload port...
Auto-detected: COM3
Uploading .pio\build\uno\firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio\build\uno\firmware.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.08s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against .pio\build\uno\firmware.hex:
avrdude: load data flash data from input file .pio\build\uno\firmware.hex:
avrdude: input file .pio\build\uno\firmware.hex contains 444 bytes
Reading | ################################################## | 100% 0.07s
avrdude: verifying ...
avrdude: 444 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
===================================================================================================================================================== [SUCCESS] Took 3.42 seconds ====================================================================================================================================================
What did I miss here? Thanks!
