Hi all, just upgraded CLion and I can’t get the Serial Monitor to work. I’m not seeing any error - it’s just that all the serial print statements that were working on previous version of CLion with old serial monitor plugin are now printing nothing.
So I’m missing some new setting in the ini file or something?
This is all I see in the terminal output.
Leaving… Hard resetting via RTS pin… — Terminal on COM9 | 115200 8-N-1 — Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time — More details at Redirecting... — Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H E (12044) wifi:Set status to INIT
Code hasn’t changed since it was working with the previous CLion serial monitor plugin and older version of PlatformIO (6.1.7) - confident that code is not the issue.
Also confident that if I create a new project with minimal sketch it will work fine.
The issue is some kind configuration that wasn’t set/migrated correctly when I updated PIO and CLion to use the new plugin.
Ok - minimal sketch doesn’t work either - same thing, no error and no output.
I tried going back to my ESP8266 boards but now upload doesn’t work on those, I get the following error on both a brand new pio project with minimal sketch and also on a project that needed converting to the new pio plugin version.
“Error: Please specify upload_port for environment or use global --upload-port option.”
This is a custom board definition right? It’s not contained in here. What’s the content of your lilygo-t7-s3.json? Also what Platform: Espressif32 version is it outputting in the build log?
Their board definition is screwed, they don’t define the macro for “The USB-CDC should be initialized as serial port” so it defaults to UART (which will log into nothing as there’s no USB-UART converter on the board).
They post-fixup this flunk in the platformio.ini with
I had that exact build flag ini entry when I had the platformio.ini set to the AdafruitFeatherS3 board and env because it wouldn’t work without it. As far as I can recall - upload wouldn’t work without it, never mind serial.
In any case - with the lilygo json instead, and the new pio plugin, it makes no difference whether that buildflag ini entry is there or not. In both cases upload works fine, serial monitor is empty.
pio version by the way is
pio --version
PlatformIO Core, version 6.1.11
If it can’t find an upload port you should check in the device manager whether you actually get a new COM port when you plug in your ESP8266. If not, you’re missing drivers for a CH340 or CP2102 or whatever USB-serial chip is on there. Or your USB cable is bad. Or your USB port is bad.
yeah - well, again, 8266 board upload was working fine 2 weeks ago before I upgraded CLion plugin and PIO
EDIT: 8266 issue was wth the USB cables (4th one finally worked) - there were just so many issues migrating the ESP32 CLion project that I was the wrong frame of mind.
