dvdnwk
1
Hey,
this time I’m trying to set up debugging – native platform for starters.
CLion 2022.3
Build #CL-223.7571.171, built on November 28, 2022
✗ pio --version
PlatformIO Core, version 6.1.5
My code [branch debugging]: GitHub - MacDada/DnWiFiDoorLock at debugging
If I select target PlatformIO Upload, the console output is Hello World! 2 as expected, so it is working.
If I select target PlatformIO Debug, the console output is:
Preparing firmware for debugging...
Processing native (platform: native)
Found 8 compatible libraries
Building in debug mode
========================= [SUCCESS] Took 0.96 seconds =========================
Environment Status Duration
native SUCCESS 00:00:00.962
========================= 1 succeeded in 00:00:00.962 =========================
Reading symbols from /Users/dada/Documents/Arduino/DnWiFiDoorLock/.pio/build/native/program...
PlatformIO: debug_tool = None
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
pio_reset_run_target
That’s all, the debugger does not stop at the start of main nor at my [multiple] breakpoints. Any ideas?
dvdnwk
2
The result after trying CLI:
➜ DnWiFiDoorLock git:(debugging) ✗ pio debug -e native --interface=gdb -x .pioinit
============================================================================================= [SUCCESS] Took 0.69 seconds =============================================================================================
native SUCCESS 00:00:00.693
============================================================================================= 1 succeeded in 00:00:00.693 =============================================================================================
Temporary breakpoint 1 at 0x100003f64: file src/native.cpp, line 11.
(gdb) PlatformIO: Resume the execution to `debug_init_break = tbreak main`
Starting program: /Users/dada/Documents/Arduino/DnWiFiDoorLock/.pio/build/native/program
Unable to find Mach task port for process-id 45518: (os/kern) failure (0x5).
(please check gdb is codesigned - see taskgated(8))
(gdb)
it appears to be working [?], but I have no idea how to use it, so I’d rather stick to the IDE.
