Platform: Windows 10
Board: Wemos D1 mini
Installed python 3.8, then:
Did following under git bash (msys2) :
$ virtualenv ~/.platformio/penv
$ source ~/.platformio/penv/
$ pip install platformio
$ source ~/.platformio/penv/Scripts/activate
To ensure that CLion/cmake reach platformio binary I also added “~/.platformio/penv/Scripts” to PATH in Windows system
Then:
# Created project with platformIO
$ mkdir ~/dev/clion/foobar; cd ~/dev/clion/foobar
$ platformio init --ide clion --board d1_mini
# copied example into src folder
$ cp /tmp/main.cpp src/
# build the project, no errors
$ platformio run
I now imported the project into CLion and things look ok. All run configurations are there
When I build the project it compiles ok but I get a linker error:
xtensa-lx106-elf/bin/ld.exe: unrecognized option ‘–major-image-version’
Full output in CLion:
====================[ Build | PLATFORMIO_BUILD | d1_mini ]======================
"C:\Program Files\JetBrains\CLion 2019.2\bin\cmake\win\bin\cmake.exe" --build C:\Users\erikb\dev\clion\foobar\cmake-build-d1_mini --target PLATFORMIO_BUILD -- -j 6
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 2.3.3 > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20603.200130 (2.6.3)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.191122 (4.8.2)
Found 29 compatible libraries
Archiving .pio\build\d1_mini\libFrameworkArduinoVariant.a
Indexing .pio\build\d1_mini\libFrameworkArduinoVariant.a
Archiving .pio\build\d1_mini\libFrameworkArduino.a
Indexing .pio\build\d1_mini\libFrameworkArduino.a
Linking .pio\build\d1_mini\firmware.elf
Retrieving maximum program size .pio\build\d1_mini\firmware.elf
Checking size .pio\build\d1_mini\firmware.elf
RAM: [=== ] 32.7% (used 26804 bytes from 81920 bytes)
Flash: [== ] 24.5% (used 256312 bytes from 1044464 bytes)
========================= [SUCCESS] Took 2.49 seconds =========================
Built target PLATFORMIO_BUILD
Build finished
====================[ Build | Z_DUMMY_TARGET | d1_mini ]========================
"C:\Program Files\JetBrains\CLion 2019.2\bin\cmake\win\bin\cmake.exe" --build C:\Users\erikb\dev\clion\foobar\cmake-build-d1_mini --target Z_DUMMY_TARGET -- -j 6
[ 50%] Linking CXX executable Z_DUMMY_TARGET.exe
c:/users/erikb/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: unrecognized option '--major-image-version'
c:/users/erikb/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: use the --help option for usage information
mingw32-make.exe[3]: *** [CMakeFiles\Z_DUMMY_TARGET.dir\build.make:86: Z_DUMMY_TARGET.exe] Error 1
mingw32-make.exe[2]: *** [CMakeFiles\Makefile2:423: CMakeFiles/Z_DUMMY_TARGET.dir/all] Error 2
mingw32-make.exe[1]: *** [CMakeFiles\Makefile2:430: CMakeFiles/Z_DUMMY_TARGET.dir/rule] Error 2
mingw32-make.exe: *** [Makefile:273: Z_DUMMY_TARGET] Error 2
Only reference I can find to major-image-version is in link.txt file under cmake-build-d1_mini . The content of the file is:
"C:\Program Files\JetBrains\CLion 2019.2\bin\cmake\win\bin\cmake.exe" -E remove -f CMakeFiles\Z_DUMMY_TARGET.dir/objects.a
C:\mingw-w64\i686-8.1.0-posix-dwarf-rt_v6-rev0\mingw32\bin\ar.exe cr CMakeFiles\Z_DUMMY_TARGET.dir/objects.a @CMakeFiles\Z_DUMMY_TARGET.dir\objects1.rsp
C:\Users\erikb\.platformio\packages\toolchain-xtensa\bin\xtensa-lx106-elf-g++.exe -fno-rtti -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -U__STRICT_ANSI__ -ffunction-sections -fdata-sections -fno-exceptions -Wall -Wl,--whole-archive CMakeFiles\Z_DUMMY_TARGET.dir/objects.a -Wl,--no-whole-archive -o Z_DUMMY_TARGET.exe -Wl,--out-implib,libZ_DUMMY_TARGET.dll.a -Wl,--major-image-version,0,--minor-image-version,0 @CMakeFiles\Z_DUMMY_TARGET.dir\linklibs.rsp
