I have another library dependencies question. Let’s say I have the following library structure:
-- LibFolder
|-- LIB_A
|-- LIB_B
Each libray is dependent to each other, means LIB_A is dependent on LIB_B, but LIB_B is also dependent to LIB_A.
LIB_A library.json:
"name": "LIB_A",
"version": "0.0.1",
"description": "This library is used as an example.",
"frameworks": [
"chiisai"
"dependencies": {
"LIB_B": "file://LibFolder/LIB_B"
LIB_B library.json:
"name": "LIB_B",
"version": "0.0.1",
"frameworks": [
"chiisai"
"dependencies": {
"LIB_A": "file://LibFolder/LIB_A"
The issue occurs when I now install one of the two libraries with the pkg install command. It is adding every instance twice.
Is this really the indendent behaviour? In my eyes, it should be possible when adding LIB_A, LIB_B should also be added, and also the other way round when adding LIB_B. I know that I could theoretically combine both libraries, but I want to keep them separated.
