If I compile a CI command twice using --keep-build-dir
I get the following error:
pio ci -b uno --build-dir C:\Users\ll\Desktop\build\test --keep-build-dir C:\Users\ll\Desktop\test\src\test.ino
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\platformio\__main__.py", line 120, in main
cli(None, None, None)
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 700, in __call__
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 680, in main
rv = self.invoke(ctx)
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 1027, in invoke
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 873, in invoke
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 508, in invoke
return callback(*args, **kwargs)
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\click\decorators.py", line 16, in new_func
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\platformio\commands\ci.py", line 99, in cli
_copy_contents(join(build_dir, dir_name), contents)
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\site-packages\platformio\commands\ci.py", line 137, in _copy_contents
makedirs(dst_dir)
File "c:\users\ll\appdata\local\programs\python\python37-32\lib\os.py", line 221, in makedirs
mkdir(name, mode)
FileExistsError: [WinError 183] Cannot create a file when that file already exists: 'C:\\Users\\ll\\Desktop\\build\\test\\src'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
Shouldn’t be possible to compile the sketch all the time replacing the file from source? there is a different solution besides to erase the build folder?
Windows 10
PIO: 4.0.0a4
