I have been using PlatformIO to upload successfully to Arduino boards on a couple of different Ubuntu Linux machines. However today when I installed on Ubuntu running on my Chromebook (via crouton) I get an error when I run
pio serialports list
File "/usr/local/lib/python2.7/dist-packages/platformio/__main__.py", line 107, in main
cli(None, None, None)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 700, in __call__
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 680, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1027, in invoke
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 873, in invoke
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 508, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/platformio/commands/serialports.py", line 40, in serialports_list
for item in get_serialports():
File "/usr/local/lib/python2.7/dist-packages/platformio/util.py", line 290, in get_serialports
for p, d, h in comports():
File "/usr/lib/python2.7/dist-packages/serial/tools/list_ports_posix.py", line 122, in comports
return [(d, describe(d), hwinfo(d)) for d in devices]
File "/usr/lib/python2.7/dist-packages/serial/tools/list_ports_posix.py", line 93, in describe
return usb_lsusb_string(sys_usb)
File "/usr/lib/python2.7/dist-packages/serial/tools/list_ports_posix.py", line 80, in usb_lsusb_string
return base
and when I try and upload
sudo pio -t upload
I get error:
scons: *** [upload] NameError : global name 'base' is not defined
File "/home/glyn/.platformio/packages/tool-scons/script/../engine/SCons/Action.py", line 1063, in execute
result = self.execfunction(target=target, source=rsources, env=env)
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/scripts/atmelavr.py", line 49, in BeforeUpload
env.AutodetectUploadPort()
File "/home/glyn/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224, in __call__
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/pioupload.py", line 125, in AutodetectUploadPort
env.Replace(UPLOAD_PORT=_look_for_serial_port())
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/pioupload.py", line 100, in _look_for_serial_port
for item in util.get_serialports():
return base
NameError: global name 'base' is not defined
I am running pyserial==3.1.1
, full freeze output:
adium-theme-ubuntu==0.3.4
apt-xapian-index==0.45
backports-abc==0.4
backports.ssl-match-hostname==3.5.0.1
bottle==0.12.9
certifi==2016.2.28
cffi==1.6.0
chardet==2.0.1
click==5.1
colorama==0.3.7
command-not-found==0.3
cryptography==1.4
debtagshw==0.1
defer==1.0.6
derpconf==0.7.3
dirspec==13.10
enum34==1.1.6
esptool==0.1.0
futures==3.0.5
gyp==0.1
html5lib==0.999
httplib2==0.8
idna==2.1
ipaddress==1.0.16
libthumbor==1.3.1
lockfile==0.12.2
lxml==3.3.3
Nautilus-scripts-manager==1.7
ndg-httpsclient==0.4.1
numpy==1.8.2
oauthlib==0.6.1
oneconf==0.3.7.14.4.1
openshot==1.4.3
PAM==0.4.2
pexif==0.15
pexpect==3.1
Pillow==2.3.0
piston-mini-client==0.7.5
platformio==2.10.1
Pmw==1.3.2
pyasn1==0.1.9
pycparser==2.14
pycrypto==2.6.1
pycups==1.9.66
pycurl==7.19.3
pygobject==3.12.0
pyOpenSSL==16.0.0
pyserial==3.1.1
pysmbc==1.0.14.1
python-apt===0.9.3.5ubuntu2
python-debian===0.1.21-nmu2ubuntu2
python-magic==0.4.11
pytz==2016.4
pyxdg==0.25
reportlab==3.0
requests==2.10.0
sessioninstaller==0.0.0
singledispatch==3.4.0.3
six==1.10.0
software-center-aptd-plugins==0.0.0
statsd==3.2.1
system-service==0.1.6
tornado==4.3
Twisted-Core==13.2.0
Twisted-Web==13.2.0
unity-lens-photos==1.0
uptime==3.0.1
urllib3==1.7.1
wxPython==3.0.1.1
wxPython-common==3.0.1.1
xdiagnose===3.6.3build2
xmltodict==0.10.1
zope.interface==4.0.5
This seems to be the latest pyserial package version.
I have installed the udev rules. My serial device is as follows:
[68760.133280] usb 1-2: Product: FT232R USB UART
[68760.133292] usb 1-2: Manufacturer: FTDI
[68760.133303] usb 1-2: SerialNumber: A700ejYh
[68760.136203] ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[68760.136294] usb 1-2: Detected FT232RL
[68760.136306] usb 1-2: Number of endpoints 2
[68760.136319] usb 1-2: Endpoint 1 MaxPacketSize 64
[68760.136331] usb 1-2: Endpoint 2 MaxPacketSize 64
[68760.136343] usb 1-2: Setting MaxPacketSize 64
[68760.136713] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB9
Have you seen this error before? Any idea what I can try?
