Hi all,
I am building an Mbed OS application for nRF52840 (Cortex-M4) and am including a third party compiled library file (.a file) into my project. During linking i get the following error:
/root/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: error: lib/RTE_OFS/libOFS_0.a(vl53l1_hist_algos_gen3.o) uses VFP register arguments, .pio/build/release/firmware.elf does not
/root/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file lib/RTE_OFS/libOFS_0.a(vl53l1_hist_algos_gen3.o)
/root/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: error: lib/RTE_OFS/libOFS_0.a(vl53l1_sigma_estimate.o) uses VFP register arguments, .pio/build/release/firmware.elf does not
/root/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file lib/RTE_OFS/libOFS_0.a(vl53l1_sigma_estimate.o)
After initial searches, i was able to narrow down the issue to a mismatch in -mfloat-abi build options used between my project and the library. I was able to confirm with the third party that they are using hard floating point.
When i build the project in verbose mode i see the following output:
Compiling .pio/build/release/FrameworkMbed/cmsis/TARGET_CORTEX_M/mbed_tz_context.o
Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
Target: arm-none-eabi
Configured with: /tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/src/gcc/configure --target=arm-none-eabi --prefix=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native --libexecdir=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/lib --infodir=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/install-native/arm-none-eabi --build=x86_64-linux-gnu --host=x86_64-linux-gnu --with-gmp=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/build-native/host-libs/usr --with-mpfr=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/build-native/host-libs/usr --with-mpc=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/build-native/host-libs/usr --with-isl=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/build-native/host-libs/usr --with-libelf=/tmp/jenkins/jenkins-GCC-7-build_toolchain_docker-633_20171130_1512067137/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for Arm Embedded Processors 7-2017-q4-major' --with-multilib-list=rmprofile
Thread model: single
gcc version 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204] (GNU Tools for Arm Embedded Processors 7-2017-q4-major)
COLLECT_GCC_OPTIONS='-o' '.pio/build/release/FrameworkMbed/cmsis/TARGET_CORTEX_M/mbed_tz_context.o' '-c' '-v' '-c' '-Wall' '-Wextra' '-Wno-unused-parameter' '-Wno-missing-field-initializers' '-fmessage-length=0' '-fno-exceptions' '-ffunction-sections' '-fdata-sections' '-funsigned-char' '-MMD' '-fno-delete-null-pointer-checks' '-fomit-frame-pointer' '-Os' '-g' '-D' 'MBED_TRAP_ERRORS_ENABLED=1' '-mcpu=cortex-m4' '-mthumb' '-mfpu=fpv4-sp-d16' '-mfloat-abi=softfp' ...
Notice that -mfloat-abi=softfp option is used.
I want to make my application also use hard floating point. After a bit more searching of how i could do this, i came across multiple posts where the suggested action was to create a small extra python script to append linker flags. So i created the below python script link_hardfloat.py:
Import("env")
flags = [
"-mfloat-abi=hard"
env.Append(CCFLAGS=flags, LINKFLAGS=flags)
and made the necessary change in platformio.ini:
[env:release]
extra_scripts =
pre:link_hardfloat.py
When i build the project again in verbose mode i see the following output:
COLLECT_GCC_OPTIONS='-o' '.pio/build/release/FrameworkMbed/cmsis/TARGET_CORTEX_M/mbed_tz_context.o' '-c' '-mfloat-abi=hard' '-v' '-c' '-Wall' '-Wextra' '-Wno-unused-parameter' '-Wno-missing-field-initializers' '-fmessage-length=0' '-fno-exceptions' '-ffunction-sections' '-fdata-sections' '-funsigned-char' '-MMD' '-fno-delete-null-pointer-checks' '-fomit-frame-pointer' '-Os' '-g' '-D' 'MBED_TRAP_ERRORS_ENABLED=1' '-mcpu=cortex-m4' '-mthumb' '-mfpu=fpv4-sp-d16' '-mfloat-abi=softfp' ...
and still get the … uses VFP register arguments, .pio/build/release/firmware.elf does not error.
Is it correct for the -mfloat-abi build option to appear twice like this? Am i on the right track here?
Any help here would be much appreciated. Thank you.
