I’ve tried modifying
platform = https://github.com/platformio/platform-espressif32.git#feature/stage
to
platform = https://github.com/espressif/arduino-esp32.git
The change resulted in the inability to build a project:
Processing esp32doit-devkit-v1 (framework: arduino; platform: https://github.com/espressif/arduino-esp32.git; board: esp32dev)
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/__main__.py", line 120, in main
cli(None, None, None)
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/core.py", line 700, in __call__
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/core.py", line 680, in main
rv = self.invoke(ctx)
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/core.py", line 1027, in invoke
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/core.py", line 873, in invoke
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/core.py", line 508, in invoke
return callback(*args, **kwargs)
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/click/decorators.py", line 16, in new_func
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/commands/run.py", line 107, in cli
result = (envname, ep.process())
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/commands/run.py", line 207, in process
result = self._run()
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/commands/run.py", line 305, in _run
p = PlatformFactory.newPlatform(self.options['platform'])
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/managers/platform.py", line 250, in newPlatform
_instance = platform_cls(join(platform_dir, "platform.json"))
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/managers/platform.py", line 460, in __init__
self._manifest = util.load_json(manifest_path)
File "/home/george/.platformio/penv/local/lib/python2.7/site-packages/platformio/util.py", line 185, in load_json
with open(file_path, "r") as f:
IOError: [Errno 2] No such file or directory: '/home/george/.platformio/platforms/arduino-esp32/platform.json'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
