hi
I was using ESP32-S3-WROOM-1 N8 dev, It’s Good.
and I’m using ESP-PROG, it worked before
but, ESP32-S3WROOM-1 N4 for production changed to chips
Now, It’s Fail!
I changed esp32-s3-devkitc-1.json, for 8->4 flash ram.
but it’s not work.
It’s Booting Log.
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x29 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376b78
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbe4
load:0x403cc700,len:0x2a38
entry 0x403c98d4
E (80) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed.
assert failed: do_core_init startup.c:326 (flash_ret == ESP_OK)
Backtrace: 0x40376f6a:0x3fceb180 0x40379625:0x3fceb1a0 0x4037efdd:0x3fceb1c0 0x42005236:0x3fceb2f0 0x403768d9:0x3fceb320 0x403cd757:0x3fceb350 0x403cda16:0x3fceb380 0x403c9929:0x3fceb4b0 0x40045c01:0x3fceb570 |<-CORRUPTED
Please show your full JSON file and the platformio.ini. Do you set a custom partition table?
Thank for interesting.
----------------------------- Platform.ini-----------------------------------------
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
upload_protocol = esptool
board_build.mcu = esp32s3
"build": {
"arduino":{
"ldscript": "esp32s3_out.ld",
"partitions": "default_8MB.csv"
"core": "esp32",
"extra_flags": [
"-DARDUINO_ESP32S3_DEV",
"-DARDUINO_USB_MODE=1",
"-DARDUINO_RUNNING_CORE=1",
"-DARDUINO_EVENT_RUNNING_CORE=1"
"f_cpu": "240000000L",
"f_flash": "40000000L",
"flash_mode": "qio",
"hwids": [
"0x303A",
"0x1001"
"mcu": "esp32s3",
"variant": "esp32s3"
"connectivity": [
"wifi"
"debug": {
"default_tool": "esp-builtin",
"onboard_tools": [
"esp-builtin"
"openocd_target": "esp32s3.cfg"
"frameworks": [
"arduino",
"espidf"
"name": "Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)",
"upload": {
"flash_size": "4MB",
"maximum_ram_size": 327680,
"maximum_size": 16777216,
"require_upload_port": true,
"speed": 460800
"url": "https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/hw-reference/esp32s3/user-guide-devkitc-1.html",
"vendor": "Espressif"
Change this to default.csv.
Thank very much for help. it’s work!
Have a Good day!
