Thanks for the heads-up, though as the toolbar is its own package and just fires the same command as the shortcut and PlatformIO menu option, it’d be ideal if the upload command could be changed globally, seeing as I now have to pull up a terminal any time I want to upload to embedded Atmega328P devices.
The toolbar does already have the ability to add custom buttons, I believe… But it just tells PlatformIO to action the upload, rather than passing the command directly. It’s PlatformIO itself that runs ‘pio run -t upload’.
