I have the following problem: I have a program in a file called main.cpp however I want to try to solve the task with a fsm to see which version wors better. So instead of deleting the old main.cpp I’d like to keep this file and build the code inside of fsm.cpp.
To do this I have added:
[env:debug]
board = uno
src_filter = -<main.cpp>
to platformio.ini.
However if I build the project using
platformio run --environment debug --target upload
I get an error saying
In function 'main':<artificial>:(.text.startup+0x86):undefined reference to 'setup'
<artificial>:(.text.startup+0x8e):undefined reference to 'loop'
However fsm.cpp contains a loop() and a setup() function.
I also tried setting
TARGET = fsm
in Makefile, but that didn’t help.
I didn’t find anything searching for a similar error so I would be glad for any idea on how to resolve this.
