Hi everyone, I had changed the repo link of my library repository and released a new version of such library with the updated library.json. However, only the “homepage” link was updated. Here a screenshot:
Is there the possibility to change the repository url to match the homepage url? Additionally, since it may be related, is it possible to change the vendor name/domain?
Done! The library was switched from the library.properties manifest to the library.json
Many thanks! But was it my fault? I have another library affected by the same issue, I don’t understand if I can fix it by myself
Done! Would you like to change the owner name to fabianoriccardi?
Yes! I had already created an account on the pio registry, but I don’t know if I should use it for this purpose…
Done! See
Please note that you can personally manage all your packages with pio pkg publish — PlatformIO latest documentation
Seen, thank you very much! Reading the docs…
