Change gdb_path
Is there a way to permanently change the gdb_path in the idedata.json? If I edit the gdb_path, to /usr/local/bin/gdb, it will be reset after every new start of vscode. If I don’t edit the variable, I always get this debug console warning:
undefinedPython Exception <type ‘exceptions.ImportError’> No module named gdb:
warning:
Could not load the Python gdb module from `/Users/jenkins/jenkins/workspace/avr-gcc-staging/label/mac-mini/objdir/share/gdb/python’.
Limited Python support is available from the _gdb module.
Suggest passing --data-directory=/path/to/gdb/data-directory.
I have read and googled a lot, but have not found the right solution, maybe it’s just adding something in the platform.ini?
Help would be much appreciated.
You need to override GBD environment variable using Advanced Scripting — PlatformIO latest documentation
Thank you very much, but I still don’t get it.
I made an extra.py file, added it platformio.ini.
I am not familiar with python, so I tried this code:
Import(“env”)
env.Replace(
GDB ="/usr/local/bin/gdb"
Found another solution, by replacing the avr-gdb inside platformio folder with the avr-gdb from Homebrew. Not the best solution, but it works, for now.
