Hi There
I have started a new project where I need to modify some few new options that espressif added to the bootloader, To date I have used the command pio run -t menuconfig
that works great.
As I already have several projects done in espressif 3.3.0 I would not like to touch / alter it and keep it the same. I learned here to set an specific version just for this new project by modifying platformio.ini
platform = espressif32@5.3.0
Howerver, it’s seems that pio run -t menuconfig
still uses my main 3.3 installation and I wonder how can fix that.
PLATFORM: Espressif 32 (**5.3.0**) > Espressif ESP32 Dev Module
- **framework-espidf @ 3.40403.0 (4.4.3)**
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40400.0 (4.4.0)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
[notice] A new release of pip is available: 24.0 -> 24.2
[notice] To update, run: python.exe -m pip install --upgrade pip
Found 0 compatible libraries
Running menuconfig...
[0/1] cmd.exe /C "cd /D C:\Projects\BOOTLOADER\.pio\build\esp32dev && C:\Users\User\.platfo...TARGET=esp32 --env IDF_ENV_FPGA= --output config
C:/Users/User/.platformio/packages/**framework-espidf@3.40403.0/Kconfig**:14: warning: IDF_ENV_FPGA has 'option env="IDF_ENV_FPGA"'
