Hi!
I’m looking to install and use the PlatformIO IDE VSCode extension on my M3 MacBook.
Upon doing so, I get what appear to be SSL certificate errors, and I’m unable to open PlatformIO Home:
ERR [Extension Host] RequestError: write EPROTO 1219782779200:error:100000f7:SSL routines:OPENSSL_internal:WRONG_VERSION_NUMBER:../../third_party/boringssl/src/ssl/tls_record.cc:231:
at ClientRequest.<anonymous> (/Users/dj/.vscode/extensions/platformio.platformio-ide-3.3.3-darwin-arm64/node_modules/got/dist/source/core/index.js:970:111)
at Object.onceWrapper (node:events:634:26)
at ClientRequest.emit (node:events:531:35)
at ClientRequest.emit (node:domain:488:12)
at origin.emit (/Users/dj/.vscode/extensions/platformio.platformio-ide-3.3.3-darwin-arm64/node_modules/@szmarczak/http-timer/dist/source/index.js:43:20)
at TLSSocket.socketErrorListener (node:_http_client:500:9)
at TLSSocket.emit (node:events:519:28)
at TLSSocket.emit (node:domain:488:12)
at emitErrorNT (node:internal/streams/destroy:169:8)
at emitErrorCloseNT (node:internal/streams/destroy:128:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:95:16)
ERR [Extension Host] RequestError: unable to get local issuer certificate
at TLSSocket.onConnectSecure (node:_tls_wrap:1674:34)
at TLSSocket._finishInit (node:_tls_wrap:1085:8)
at ssl.onhandshakedone (node:_tls_wrap:871:12)
I tried adding the following lines to my vscode settings.json file, then uninstalling and reinstalling the extension, but that didn’t fix the issue (also seems like a horrible setting to require):
"http.proxyStrictSSL": false,
"http.proxyAuthorization": null,
"http.systemCertificates": false,
I also tried removing my ~/.platformio folder (which only included a .cache folder) and reinstalling the extension, but to no avail.
Potentially relevant details:
- OS: macOS 14.6.1
- Architecture: arm64
- Python: 3.12.5
- pip: 24.2
- vscode: 1.93.0
I don’t have any network proxies or VPNs enabled in my system settings as far as I can tell.
Note: I know next to nothing about SSL certificates, so if I have to update my certificate settings to fix the issue, you’ll have to talk to me like I’m 5 ![]()
