I have a project which will span several boards. I have reviewed the documentation and am a bit confused about how to pull this off.
It seems like the board definition is required as a common element:
; Global data for all [env:***]
[env]
framework = espidf
In my case, I have esp8266, esp32, atmelavr, etc. so that’s not going to work. Am I trying to do something that PIO will not allow?
Secondarily, may these be cascaded? e.g. platformio.ini
has an extra_configs
section, and each board has it’s own separate extra_configs
? The reason I want to do this is right now I have a config.h
file with a TON of declarations. Adding new boards makes that even messier. If I could somehow cascade the declaration configuration file with a build_flags
specific to each board, that would be easier to maintain.
