Hi There,
I’m new here, and sorry if answer has already been answered but I did not found it here nor on google. And it drive me crazy.
I’m using pio with ESP32, all works fine but I need to capture compilation terminal output. Why can’t I just select output to do “copy”?
I saw somewhere a pio run >>file.log but the output does not contains the compilation error that are on the screen when I build without redirection.
Don’t tell me I’m the only one having this issue?
Thanks for your help
I can answer the second part of that question: Error messages get written to stderr instead of stdout. Now depending on your operating system you can redirect streams, in particular stderr to stdout.
Linux (possibly also Mac):
pio run > file.log 2>&1
Windows:
pio run 1> file.log 2>&1
For the first part: If you run it from terminal you should still be able to select and copy-paste the output. Or are you running it inside some IDE? What OS/IDE?
@maxgerhardt, thanks, my fault I totally forgot to mention, I’m on Win10 in PIO Integrated IDE (no terminal)
And this line works great under windows
Thanks for all, to be honest, It’s the first ide I can’t select what is displayed on screen ever, but I can live with it
Remember you can always tell PIO to generate project files for other IDEs if you don’t like the supplied one. I personally like CLion, Visual Studio Code and Eclipse
(pio init -h)
I’m coming from Sublime/Arduino/Nodepad++/Vstudio but I like PIO no problem
