Hello Folks,
I try to upload a minimal code example, so just empty void setup() and void loop().
I can upload this with the Arduino IDE.
I can build it using PIO, but not upload it.
Correct COM Port and Board are specified.
main.cpp:
platformio.ini:
[env:wemos_d1_mini32]
board = wemos_d1_mini32
Upload error i am getting:
* Executing task: C:\Users\Florian\.platformio\penv\Scripts\platformio.exe run --target upload
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 (1.12.1) > WeMos D1 MINI ESP32
- framework-arduinoespressif32 @ 3.10004.200129 (1.0.4)
- tool-esptoolpy @ 1.20600.0 (2.6.0)
- toolchain-xtensa32 @ 2.50200.80 (5.2.0)
Found 33 compatible libraries
Retrieving maximum program size .pio\build\wemos_d1_mini32\firmware.elf
Checking size .pio\build\wemos_d1_mini32\firmware.elf
RAM: [ ] 4.5% (used 14700 bytes from 327680 bytes)
Flash: [== ] 16.0% (used 209803 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM5
Uploading .pio\build\wemos_d1_mini32\firmware.bin
esptool.py v2.6
Serial port COM5
Connecting....
A fatal error occurred: Timed out waiting for packet header
*** [upload] Error 2
====================================================================================================== [FAILED] Took 5.66 seconds ======================================================================================================
* The terminal process "C:\Users\Florian\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
Auto-detected: COM5
esptool.py v2.6
Serial port COM5
Connecting....
====================================================================================================== [FAILED] Took 7.68 seconds ======================================================================================================
Any idea how to fix this?
