If you just want a basic example, you could add this as src/entry.S: (just entry.S with two function calls / references commented out)
/* Copyright 2018 SiFive, Inc */
/* SPDX-License-Identifier: Apache-2.0 */
/* This code executes before _start, which is contained inside the C library.
* In embedded systems we want to ensure that _enter, which contains the first
* code to be executed, can be loaded at a specific address. To enable this
* feature we provide the '.text.metal.init.enter' section, which is
* defined to have the first address being where execution should start. */
.section .text.metal.init.enter
.global _enter
_enter:
.cfi_startproc
/* Inform the debugger that there is nowhere to backtrace past _enter. */
.cfi_undefined ra
/* The absolute first thing that must happen is configuring the global
* pointer register, which must be done with relaxation disabled because
* it's not valid to obtain the address of any symbol without GP
* configured. The C environment might go ahead and do this again, but
* that's safe as it's a fixed register. */
.option push
.option norelax
#ifdef __riscv_cmodel_compact
1:
auipc a0, %pcrel_hi(__global_pointer__)
addi a0, a0, %pcrel_lo(1b)
ld gp, 0(a0)
add gp, gp, a0
#else
la gp, __global_pointer$
.option pop
/* trap over the chicken bit register clearing, aloe & fe310 dont have it */
la t0, 1f
csrw mtvec, t0
/* chicken bit is enable if core are sifive series. */
la t0, __metal_chicken_bit
beqz t0, 1f
/* If set, always clear the feature disable register for all cores series */
csrwi 0x7C1, 0
.align 4
1:
/* Set up a simple trap vector to catch anything that goes wrong early in
* the boot process. */
// don't do that
//la t0, early_trap_vector
//csrw mtvec, t0
/* There may be pre-initialization routines inside the MBI code that run in
* C, so here we set up a C environment. First we set up a stack pointer,
* which is left as a weak reference in order to allow initialization
* routines that do not need a stack to be set up to transparently be
* called. */
.weak __metal_stack_pointer
la sp, __metal_stack_pointer
/* The METAL is designed for a bare-metal environment and therefore is expected
* to define its own stack pointer. We also align the stack pointer here
* because the only RISC-V ABI that's currently defined, mandates 16-byte
* stack alignment. */
bne sp, zero, 1f
lla.gprel sp, _sp
#else
la sp, _sp
1:
/* Increment by hartid number of stack sizes */
csrr a0, mhartid
li t0, 0
la t1, __stack_size
1:
andi sp, sp, -16
beq t0, a0, 1f
add sp, sp, t1
addi t0, t0, 1
j 1b
1:
/* Check for an initialization routine and call it if one exists, otherwise
* just skip over the call entirely. Note that __metal_initialize isn't
* actually a full C function, as it doesn't end up with the .bss or .data
* segments having been initialized. This is done to avoid putting a
* burden on systems that can be initialized without having a C environment
* set up. */
// don't do that
//la ra, __metal_before_start
//beqz ra, 1f
//jalr ra
1:
/* At this point we can enter the C runtime's startup file. The arguments
* to this function are designed to match those provided to the SEE, just
* so we don't have to write another ABI. */
csrr a0, mhartid
li a1, 0
li a2, 0
call _start
/* If we've made it back here then there's probably something wrong. We
* allow the METAL to register a handler here. */
.weak __metal_after_main
la ra, __metal_after_main
beqz ra, 1f
jalr ra
1:
/* If that handler returns then there's not a whole lot we can do. Just
* try to make some noise. */
la t0, 1f
csrw mtvec, t0
1:
lw t1, 0(x0)
j 1b
.cfi_endproc
/* The GCC port might not emit a __register_frame_info symbol, which eventually
* results in a weak undefined reference that eventually causes crash when it
* is dereference early in boot. We really shouldn't need to put this here,
* but to deal with what I think is probably a bug in the linker script I'm
* going to leave this in for now. At least it's fairly cheap :) */
.weak __register_frame_info
.section .text.metal.init.__register_frame_info
__register_frame_info:
.cfi_startproc
ret
.cfi_endproc
And this file as src/link.ld.
Then have
[env:sparkfun_thing_plus_v]
platform = sifive
board = sparkfun_thing_plus_v
board_build.ldscript = src/link.ld
as platformio.ini. The _entry should now be at the correct place, the firmware should be uploadable.
> C:\Users\Max\.platformio\packages\toolchain-riscv\bin\riscv64-unknown-elf-objdump.exe -D .\.pio\build\sparkfun_thing_plus_v\firmware.elf
.\.pio\build\sparkfun_thing_plus_v\firmware.elf: file format elf32-littleriscv
Disassembly of section .init:
20010000 <_enter>:
20010000: 5fff1197 auipc gp,0x5fff1
20010004: 80018193 addi gp,gp,-2048 # 80000800 <__global_pointer$>
20010008: 00000297 auipc t0,0x0
