peter69
February 23, 2023, 12:35am
#1
When trying to upload to an STM32F103C8 I get the following error:
# A fatal error has been detected by the Java Runtime Environment
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=14788, tid=0x0000000000000a18
# JRE version: Java™ SE Runtime Environment (8.0_361) (build 1.8.0_361-b09)
# Java VM: Java HotSpot™ 64-Bit Server VM (25.361-b09 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [jSSC-2.8_x86_64.dll+0xb5db]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Can anyone help to fix this issue? Thanks a lot, in advance for your help.
Best,
Peter
peter69
February 23, 2023, 8:16pm
#3
Sorry, I don’t understand your question.
You wrote in the PlatformIO forum. I assume you’re thus using PlatformIO. Every PlatformIO project has a platformio.ini
file in which you configure build and upload options. I want to see the contents of the platformio.ini
with which the upload is failing for you.
peter69
February 23, 2023, 9:15pm
#5
Ok! Thanks for the clarification. Following the platformio.ini:
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
board_build.core = maple
upload_protocol = dfu
See
https://www.stm32duino.com/viewtopic.php?t=604
committed 08:50PM - 16 Dec 20 UTC
Merge pull request #814 from dadul96/Fix_Java_PATH_problem_Windows
Thanks a lot for the link! I really appreciate it.
Hello
I could use a little more help to resolve the issue ‘EXCEPTION_ACCESS_VIOLATION (0xc0000005)’ while uploading to a STM32F108 on PIO.
The ‘maple_upload.bat’ and ‘platform.txt’ were modified according the description at ‘https://github.com/rogerclarkmelbourne/Arduino_STM32/commit/0484ef74ed1f98e4e67691c58470b06f538824d9’ , but the error persists.
I get the same error when using the Arduino IDE 2.0.4. I would very much appreciate any help on this matter. Thanks a lot in advance!
Best,
Peter
