Hi all,
I am trying to upload a simple sketch to my ESP32-C3 from Lolin using platformio.
It works perfectly if I switch to ESP32 but not on ESP32-C3.
this is the error:
Retrieving maximum program size .pio\build\glowwormluciferinfull_esp32\firmware.elf
Checking size .pio\build\glowwormluciferinfull_esp32\firmware.elf
RAM: [== ] 20.0% (used 65508 bytes from 327680 bytes)
Flash: [======== ] 77.3% (used 1013200 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-us
b-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Using manually specified: COM10
Uploading .pio\build\glowwormluciferinfull_esp32\firmware.bin
esptool.py v4.5.1
Serial port COM10
A fatal error occurred: Could not open COM10, the port doesn't exist
*** [upload] Error 2
============================================== [FAILED] Took 5.88 seconds ==============================================
Environment Status Duration
glowwormluciferinfull_esp32 FAILED 00:00:05.883
======================================== 1 failed, 0 succeeded in 00:00:05.883 ========================================
Process finished with exit code 1
this is my platformio.ini
[env:glowwormluciferinfull_esp32]
platform = espressif32@6.2
board = lolin_c3_mini
board_build.mcu = esp32c3
any idea on what could it be the problem? thanks
I have another error now:
RAM: [== ] 21.7% (used 71052 bytes from 327680 bytes)
Flash: [======== ] 82.4% (used 1079525 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex
Using manually specified: \\.\COM10
esptool.py v4.5.1
Serial port \\.\COM10
Connecting...
Device PID identification is only supported on COM and /dev/ serial ports.
A serial exception error occurred: Write timeout
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or
drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
*** [upload] Error 1
Very borked. Is this your board?
https://www.wemos.cc/en/latest/c3/c3_mini.html
What happens without upload_port
being set?
I have a lot of boards to try, I have dev kits from Espressif,
Tiny boards from Unexpected maker and boards from Lolin.
I have ESP32 C3, S2 and S3. every boards shows similar errorsâŚ
removing the upload_port does not solve the error.
I have done this:
Upload Code
- Make C3 boards into Device Firmware Upgrade (DFU) mode.
- Hold on Button 9
- Press Button Reset
- Release Button 9 When you hear the prompt tone on usb reconnection
as written here:
https://www.wemos.cc/en/latest/tutorials/c3/get_started_with_arduino_c3.html
and it started working.
Hi, Iâm currently experiencing the same issue but with something that isnât an Arduino board (which it appears to me what the same case for you).
To make this a bit more explicitly obvious what is meant by making the (in my case a) board into "Device Firmware Upgrade (DFU) mode. How did you do this?
Is Button 9 a physical button labelled 9?
Is the reset button a traditional reset button found on many Arduino boards?
Thank you in advance for having dedicated your time to sharing the solution to a problem which no longer is your problem, too many threads end with something along the lines of âI fixed it now thanksâ without any explanation as to how.
hi,
I canât upload firmware to esp32-c3 super mini
pload_port = \.\COM4 â Com Ports" in Device Manager in Windows 10 when in DFU mode
;upload_speed = 2000000
upload_speed = 115200
Thanks in advance for any help you may have,
Chip is ESP32-C3 (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: dc:da:0c:8e:ba:e0
Uploading stubâŚ
Running stubâŚ
Stub runningâŚ
Configuring flash sizeâŚ
Flash will be erased from 0x00000000 to 0x00003fffâŚ
Flash will be erased from 0x00008000 to 0x00008fffâŚ
Flash will be erased from 0x0000e000 to 0x0000ffffâŚ
Flash will be erased from 0x00010000 to 0x000fafffâŚ
Compressed 13216 bytes to 9529âŚ
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
