hello everyone
i have recently installed VSCode with platformio to program an esp2866 board.
Yesterday i had no problems uploading my code to the board but today i get an error when i try uploading the same code.
"A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header"
When i only comiple the code ther is no problem. I have also tried another board but got the same error.
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (2.6.2) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- tool-mklittlefs 1.203.200522 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Found 29 compatible libraries
Retrieving maximum program size .pio\build\nodemcuv2\firmware.elf
Checking size .pio\build\nodemcuv2\firmware.elf
RAM: [=== ] 32.7% (used 26824 bytes from 81920 bytes)
Flash: [== ] 24.6% (used 257440 bytes from 1044464 bytes)
AVAILABLE: espota, esptool
Looking for upload port...
Auto-detected: COM3
Uploading .pio\build\nodemcuv2\firmware.bin
esptool.py v2.8
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____....._____
*** [upload] Error 2
=================================================================== [FAILED] Took 27.68 seconds ===================================================================The terminal process "C:\Users\Dirk-\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
hopefully somone can help me.
