I’m using VS Code with Platform.IO for different newer AVR microcontrollers (Attiny3216, AVR128, Atmega 3208…) for a while now without any problems, but now I ran into an issue I cannot figure out:
I created a project for an Attiny13A, framework is Arduino, platform is Atmel AVR, nothing special; as programmer I’m using an USBASP clone. Uploading works fine, but I can’t set the fuses. I get the message
avrdude: can’t open config file “C:\Users\Win”: No such file or directory
avrdude: error reading system wide
configuration file “C:\Users\Win”
*** [fuses] Error 1
It seems that avrdude cannot find the avrdude.conf, because the path contains a space (The path is “C:\Users\Win 10 Pro…”
What I cannot get is, that the upload works fine with the same tool, only the fuses setting fails?
Ofc I have reinstalled th platform,no change.
The upload related section of my platformio.ini:
upload_protocol = custom
upload_port = usb
upload_flags =
-v
-C
${platformio.packages_dir}/tool-avrdude/avrdude.conf
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
usbasp
Any help would be highl appreciated; thanks!
