And I can’t flash Arduino Nano
Found 5 compatible libraries
Scanning dependencies…
Checking size .pio\build\nanoatmega328\firmware.elf
RAM: [= ] 11.3% (used 232 bytes from 2048 bytes)
Flash: [= ] 8.3% (used 2542 bytes from 30720 bytes)
Configuring upload protocol…
AVAILABLE: arduino
Looking for upload port…
Using manually specified: COM3
Uploading .pio\build\nanoatmega328\firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x54
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x70
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2e
avrdude done. Thank you.
Happened a couple of days ago.
On another computer in Platformio , it works
