I am adding a library from GitHub as a submodule. It includes a main.cpp file that is causing multiple definition problems at the linking step. I tried excluding it using src_filter, but no luck. Of course, I can manually delete the file, but I would have to do that every time I update the submodule. I was hoping for a simple way to exclude it from the build.
[env:esp12e]
platform = espressif8266
board = esp12e
[khoih-prog/ESP_WiFiManager@^1.3.0](mailto:khoih-prog/ESP_WiFiManager@%5e1.3.0)
[arduino-libraries/NTPClient@^3.1.0](mailto:arduino-libraries/NTPClient@%5e3.1.0)
[paulstoffregen/Time@^1.6.1](mailto:paulstoffregen/Time@%5e1.6.1)
[arkhipenko/TaskScheduler@^3.3.0](mailto:arkhipenko/TaskScheduler@%5e3.3.0)
src_filter = +<*> -<.git/> -<.svn/> -<example/> -<examples/> -<test/> -<tests/>
-<src/DebounceSwitch_submodule/>
+<src/DebounceSwitch_submodule/DebounceSwitch.h>
+<src/DebounceSwitch_submodule/DebounceSwitch.cpp>
