Hello!
I recently installed PlatformIO for Vscode and I am running into an issue where I cannot see my Serial.println comments in the Serial Monitor.
I made sure to do monitor_speed in the ini file.
Here is my code:
U’re probably missing an entry in your platformio.ini file, some thing like
Try something simple first in PlatformIO, it has a steep learning curve.
Below are my platformio.ini and main.cpp contents for a BlinkLed and ‘SerialHello’…
[env:nanoatmega328]
board = nanoatmega328
;monitor_port = COM12
main.cpp
void setup()
// initialize LED digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
void loop()
Serial.println("Hello world");
// turn the LED on
// wait for a second
delay(500);
// turn the LED off
delay(500);
Now I found out the issue I’ve just reported doesn’t regard Serial.print itself.
The problem is related to the code flashing. Despite the [SUCCESS] report, the code is never flashed to the device.
I’ve tried to check with an ordinary serial monitor. When I try to flash with VSCode+PlatformIO, no Serial.print message is shown. But when I flash with Arduino IDE, all serial messages appear normally.
