HW : ESP32_devkit_v4
ESP IDF : 3.3.1
I understand that in order to add this APPTRACE module I’ve to set it in menuconfig by modifying sdkconfig.h.
But adding: #define CONFIG_APPTRACE_ENABLE 1 doesn’t work.
- Is it possible to modify and compile sdkconfig header file in platformio?
- Does someone success to run app trace example (ESP IDF)?
Thanks in advance,
It works!!!
Need to add to SDKCONFIG.H :
#define CONFIG_ESP32_APPTRACE_ENABLE 1
#define CONFIG_ESP32_APPTRACE_LOCK_ENABLE 1
#define CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS 1
#define CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS 1
#define CONFIG_FREERTOS_USE_TRACE_FACILITY 1
#define CONFIG_ESP32_APPTRACE_POSTMORTEM_FLUSH_TRAX_THRESH 0
#define CONFIG_ESP32_APPTRACE_ONPANIC_HOST_FLUSH_TMO 10000
#define CONFIG_ESP32_APPTRACE_POSTMORTEM_FLUSH_THRESH 1
#define CONFIG_ESP32_APPTRACE_PENDING_DATA_SIZE_MAX 1024
#define CONFIG_ESP32_APPTRACE_DEST_TRAX 1
#define CONFIG_ESP32_DEBUG_STUBS_ENABLE 1
#define CONFIG_ESP32_TRAX 1
#define CONFIG_ESP32_TRAX_TWOBANKS 1
In the meanwhile, I don’t know which is relevant and which not…but it works.
