I’m new to PlatformIO and can’t quite get it to work. When I try to launch a project I get an error.
What can be causeing it?
PIO Core Call Error: "The current working directory C:\Users\schif\Documents\PlatformIO\Projects\230512-201136-nanoatmega328 will be used for the project.
The next files/directories have been created in C:\Users\schif\Documents\PlatformIO\Projects\230512-201136-nanoatmega328
Resolving nanoatmega328 dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
Error: Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (4.1.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.1.0
Found 5 compatible libraries
*** SyntaxError `unexpected EOF while parsing (<string>, line 1)' trying to evaluate `$DIa31128.42220'
File "C:\Users\schif\.platformio\penv\lib\site-packages\platformio\builder\tools\piointegration.py", line 160, in DumpIntegrationData
========================== [FAILED] Took 0.57 seconds =========================="
So that’s just trying to find out what the compiler is (which should evaluate to avr-gcc located in C:\Users\<user>\.platformio\packages in your project).
You might have very weird environment variables or PATHs set. In a PlatformIO core CLI, please post the output of
