Can't make platformio to build for 8MB flash
I can’t make platformio to build partition table for 8MB flash.
I have a esp32 wroom 32ue with 8MB flash. I use the board esp32dev, here is my platformio.ini section:
[env:esp32doit-devkit-v1]
;board = esp32doit-devkit-v1
board_build.flash_size = 8MB
board_build.partitions = Partition_Table_8mb.csv
board_upload.flash_size = 8MB
board_upload.wait_for_upload_port = yes
board_upload.use_1200bps_touch = yes
monitor_port = Auto
monitor_filters = colorize
monitor_echo = yes
     ESP Async WebServer
This is the partition table:
# Name,	Type,	SubType,	Offset,	Size,	Flags
nvs,	data,	nvs,	0x9000,	0x5000,
otadata,	data,	ota,	0xe000,	0x2000,
app0,	app,	ota_0,	0x10000,	0x330000,
app1,	app,	ota_1,	0x340000,	0x330000,
spiffs,	data,	spiffs,	0x670000,	0x180000,
coredump,	data,	coredump,	0x7f0000,	0x10000,
and this is the terminal output when I build the filesystem image:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32dev; framework: arduino)
PLATFORM: Espressif 32 (6.9.0) > Espressif ESP32 Dev Module
 - framework-arduinoespressif32 @ 3.20017.0 (2.0.17)
 - tool-mkfatfs @ 2.0.1
Found 45 compatible libraries
|-- ESP Async WebServer @ 1.2.4
|-- ArduinoJson @ 7.1.0+sha.bf99aee
|-- PubSubClient @ 2.8.0+sha.2d228f2
I upload successfully but when running I get crashes like
ets Jul 29 2019 12:21:46
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13232
load:0x40080400,len:3028
entry 0x400805e4
If you see the terminal output above it reports
which is not right. I have stated board_build.flash_size = 8MB
In any case:
esptool.py --chip esp32 --port /dev/ttyUSB0 flash_id
reports
Chip is ESP32-D0WD-V3 (revision v3.1)
Manufacturer: a1
Device: 4017
Detected flash size: 8MB
Can someone help me with this? Is there any other parameter in the ini file that I should know of? Thank you.
I’m missing board_upload.maximum_size.
Try this:
board_upload.maximum_size = 8388608
monitor_echo = yes
     ESP Async WebServer
ok, now it builds reporting 8MB:
HARDWARE: ESP32 240MHz, 320KB RAM, 8MB Flash
After I upload the file system and code I boot the esp32.
The code starts but as soon as I try to initialize SPIFFS:
// Initialize SPIFFS
void initSPIFFS() {
  if (!SPIFFS.begin(true)) {
    Serial.println("An error has occurred while mounting SPIFFS");
  Serial.println("SPIFFS mounted successfully");
I get the crash error:
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805e4
It doesn’t even print the message ```
“An error has occurred while mounting SPIFFS”
Did you call initSPIFFS() in setup() ?
OK, looking into again I realized there were more calls than just initSPIFFS() in setup(). My mistake! There was a call pinMode(6, INPUT);
Pin6 in esp32-wroom-32 is somehow restricted for internal SPI_CLK, while in other mcu’s can be fully programmed (esp32-s3).
I rebuilt the files and now it works! Thank you a lot sivar2311!!
There is a great article about the GPIO’s of the ESP32 : ESP32 Pinout Reference: Which GPIO pins should you use? | Random Nerd Tutorials
RNT is a great source of info. Good call, @sivar2311.
FWIW, I’ll toss in my favorite resource for the ESP32-S3 family.
Keeping it in the family, there’s even a callback to the cited RNT page.
It’s a nicely done resource, with Atomic14 starting out and then accepting and integrating feedback from EE/SWE types that had learned related (sometimes expensive) lessons in this area. The challenge of determining authenticity from all the self-proclaimed experts is pretty real.
