I have tried including libraries into my project. I’m using pure avr-gcc without any functions or anything from any framework. However, when I try linking libraries onto it, things don’t work well.
My libraries are clonned from vcs into the lib
folder. There are two of them, OLED library depends on an I2C library. In main.cpp I only include the OLED library, as I don’t call anything from I2C library. All references to the I2C library are within the OLED library.
With line framework = arduino
in the platform.ini
file. My dependency graph looks like this:
|-- TinierI2C @ 2.0.2
|-- tinierOLED
However, when I comment that line out, it changes into this:
|-- tinierOLED
And it’s followed by many linking errors, sine it cannot find an object, which was declared as extern
in I2C library. A snippet from a long list of very simillar errors looks like this:
Linking .pio/build/ATtiny404/firmware.elf
/tmp/cc8IJbnN.ltrans0.ltrans.o: In function `SSD1306Device::ssd1306_send_command_start() [clone .constprop.11]':
<artificial>:(.text+0x8): undefined reference to `TinierI2C'
<artificial>:(.text+0xa): undefined reference to `TinierI2C'
<artificial>:(.text+0xc): undefined reference to `TinierI2CMaster::start(unsigned char, long)'
<artificial>:(.text+0x10): undefined reference to `TinierI2C'
What could cause the problem? I’m very confused, since everything works with framework set to arduino.
Full output of the command /usr/bin/pio run -t upload -e ATtiny404 -v
is here:
Processing ATtiny404 (platform: atmelmegaavr; board: ATtiny404; board_build.f_cpu: 4000000UL)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATtiny404.html
PLATFORM: Atmel megaAVR (1.9.0) > ATtiny404
HARDWARE: ATTINY404 4MHz, 256B RAM, 4KB Flash
- tool-avrdude @ 1.70100.0 (7.1.0)
Framework incompatible library /home/martin/CLionProjects/avr-radio/lib/tinier-i2c
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 1 compatible libraries
|-- tinierOLED (License: Unknown, Path: /home/martin/CLionProjects/avr-radio/lib/tinierOLED)
avr-g++ -o .pio/build/ATtiny404/src/main.o -c -std=gnu++11 -fno-exceptions -fno-threadsafe-statics -fpermissive -Wno-error=narrowing -mmcu=attiny404 -Os -w -ffunction-sections -fdata-sections -flto -DF_CPU=4000000UL -DPLATFORMIO=60106 -DARDUINO_attinyxy4 -DMILLIS_USE_TIMERA0 -DUARTBAUD5V -Iinclude -Isrc -Ilib/tinierOLED/src src/main.cpp
avr-g++ -o .pio/build/ATtiny404/lib73d/tinierOLED/tinierOLED.o -c -std=gnu++11 -fno-exceptions -fno-threadsafe-statics -fpermissive -Wno-error=narrowing -mmcu=attiny404 -Os -w -ffunction-sections -fdata-sections -flto -DF_CPU=4000000UL -DPLATFORMIO=60106 -DARDUINO_attinyxy4 -DMILLIS_USE_TIMERA0 -DUARTBAUD5V -Ilib/tinierOLED/src lib/tinierOLED/src/tinierOLED.cpp
avr-gcc-ar rc .pio/build/ATtiny404/lib73d/libtinierOLED.a .pio/build/ATtiny404/lib73d/tinierOLED/tinierOLED.o
avr-gcc-ranlib .pio/build/ATtiny404/lib73d/libtinierOLED.a
avr-g++ -o .pio/build/ATtiny404/firmware.elf -mmcu=attiny404 -Os -flto -Wl,--gc-sections -Wl,--section-start=.text=0x0 -fuse-linker-plugin .pio/build/ATtiny404/src/main.o -L.pio/build/ATtiny404 -Wl,--start-group .pio/build/ATtiny404/lib73d/libtinierOLED.a -lm -Wl,--end-group
/tmp/cc5Z20lK.ltrans0.ltrans.o: In function `SSD1306Device::ssd1306_send_command_start() [clone .constprop.11]':
<artificial>:(.text.startup+0xfa): undefined reference to `TinierI2CMaster::stop()'
*** [.pio/build/ATtiny404/firmware.elf] Error 1
