Can't install XPT2046 Touchscreen library
I am trying to add Paul Stoffregen’s XPT2046 Touchscreen library to a project but the installation fails.
My platformio.ini file:
    https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
What happens when I save platformio.ini:
Resolving esp32dev dependencies...
Library Manager: Installing git+https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
git version 2.50.1
Cloning into '/Users/dpatterson/.platformio/.cache/tmp/pkg-installing-cobcs9qw'...
fatal: not a git repository: '?]1337;SetBadgeFormat=LW4gbWFjcHJvLTIwMTkuZHBjCnRtcC9wa2ctaW5zdGFsbGluZy1jb2Jjczlxdy8uZ2l0Cgo=?/Users/dpatterson/.platformio/.cache/tmp/pkg-installing-cobcs9qw/.git'
fatal: /usr/local/opt/git/libexec/git-core/git-submodule cannot be used without a working tree.
VCSBaseException: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', 'https://github.com/PaulStoffregen/XPT2046_Touchscreen.git', '/Users/dpatterson/.platformio/.cache/tmp/pkg-installing-cobcs9qw']
Suggestions?
TIA
D.
Does
git clone https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
on a regular terminal / command line work?
PlatofrmIO is just invoking your system’s git command.
Yes. Cloning from the command line works.
From a commandline within your project folder
rm -rf /Users/dpatterson/.platformio/.cache/
rm -rf .pio
And build again.
Still get the same error.
Then something is wrong in the shell environment for PlatformIO.
Does the git clone command work in a PlatformIO Core CLI still?
Yes. Cloning works from there.
Iv’e used git lib_deps before without issue.
Is there a way to see the actual command issued by PIO?
The exact comman executed is there as the command args array:
Except that isn’t the actual command. That is what the command is built from.
Anyway, I have figured out where some of the strangeness of the error message is coming from. In
fatal: not a git repository: '?]1337;SetBadgeFormat=LW4gbWFjcHJvLTIwMTkuZHBjCnRtcC9wa2ctaW5zdGFsbGluZy1mcXl0NHppZi8uZ2l0Cgo=?
The “?]1337;SetBadgeFormat=…” is the output of a bash function that is part of my standard setup. The apparent garbage following it is actually base64-encoded text that decodes to “tmp/pkg-installing-fqyt4zif/.git”. That’s the temporary directory that the repository is being cloned to.
What I don’t know is how that is getting into the command stream. The function in question is called by my cd function when I change directories to update the iTerm “badge” with the current directory.
I tried issuing pio pkg install -l https://github.com/PaulStoffregen/XPT2046_Touchscreen.git and it fails with the same error.
How on earth is the output from a bash printf getting into the command input stream?
When you have the minimal Python script
import subprocess
cmd = [
    'git', 'clone',
    'git_clone_test']
subprocess.run(cmd, shell=True)
And you execute it in this iTerminal terminal, does it also fail?
Does it still fail with shell=False and git replaced to the path of git, likely /usr/bin/git?
That fails with a git usage error.
Okay, that’s weird.
Specifying shell=False works.
I don’t know enough about Python internals to understand what’s happening here.
I’d ditch iTerm or ask their support on why that happens.
Yeah. Not the answer.
iTerm is a very capable terminal app for the Mac that I have been using for many years.
One of its nice capabilities is to display a “badge” in the upper-right corner of the window. This badge can contain whatever text you like and is updated by sending proprietary escape sequences to the terminal.
I use this functionality in my change-directory (cd) script to update the badge with the current host name, current directory, and current git branch (if the current directory is a git repository).
It appears that the pio pkg install command script performs a cd at some point and is capturing and attempting to process the escape sequence that my cd script sends to update the badge.
iTerm, itself, has nothing to do with this problem.
I did a little digging and in platformio-core/platformio/package/manager/base.py in the call_pkg_script() function is a line that starts with with fs.cd(pkg.path):. That class does call os.chdir() in its __enter__() and __exit__() methods.
As I said, I’m no python expert so I haven’t been able to get any farther yet.
D.
CC @ivankravets weird bug on MacOS + iTerm during regular package installation, should be triggerable with pio pkg install -g -l https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
