Can't include the TinyGSM library in my esp-idf project, can't compile code
I am new to platformIO and tried to create a clean project where I can use the esp-idf framework with c++ libraries. In particular I am trying to use the TinyGSM library but I can’t compile my project. I installed the library to my project from the PIO libraries page and renamed my main.c to main.cpp as I want to write my code in c++ but have not made any changes in the project after that.
Is it not possible to use c++ with esp-idf or do I need to do additional setup before it works?
This is what my .ini file looks like,
[env:esp-wrover-kit]
board = esp-wrover-kit
framework = espidf
	vshymanskyy/TinyGSM@^0.11.7
	marcoschwartz/LiquidCrystal_I2C@^1.1.4
and this is what my main.cpp looks like
#include <TinyGsmClient.h>
extern "C" {void app_main(void){}}
void app_main(void) {}
and i get this error when running the compiler.
I have tried to restart VS code, re-installed the library, added the library in /lib/ instead but I cant seem to get it working.
Have I done my setup incorrectly?
The library is not ESP-IDF compatible. It requires the Arduino abstraction layer.
Add the Arduino framework in the mix, or switch to that framework, or use a different GSM library, or port the TinyGSM library from Arduino to ESP-IDF.
PlatformIO respects the compatibility settings of the TinyGSM library and excludes it from the build, hence “Include not found”.
The very same goes for marcoschwartz/LiquidCrystal_I2C .
Thank you for the reply! I did not realize it was only supported by the Arduino framework :sweat_smile:
I tried to make the combined environment and this worked for me :grinning:.
Just a question for curiosity. When you mention “port the TinyGSM library from Arduino to ESP-IDF” does this just include converting libraries such as Wire and other Arduino framework specific libraries to ESP-IDF or is there more to it? To me it seems like its all just source and header files after that but I am quite new to all these environments, frameworks and the likes. Again, thank you for the great answer!
could you pl help me understand how you achieved this? I am facing exact same issue, but I am a beginner trying to solve this. Could you please share your solution or help me understand what you meant by this? Thanks
Do you need to change on the underlying ESP-IDF or what is the reason?
A pure Arduino project is much easier, especially for beginners, than an Arduino as ESP-IDF component project.
