Cant get the unit test work with custom unity_config.h
Hi ,
I want to perform a unit test for arduino based stm32 device. The serial output of the test device need to port to hardware serial .
Before platformio core 6.0 it was working fine with unittest_transport.h
which the code is ::
#ifndef UNITTEST_TRANSPORT_H
#define UNITTEST_TRANSPORT_H
#define TESTING_SERIAL Serial1
HardwareSerial Serial1(UART4);
void unittest_uart_begin() {
/* default test_speed value */
TESTING_SERIAL.setRx(PC11);
TESTING_SERIAL.setTx(PC10);
TESTING_SERIAL.begin(115200);
void unittest_uart_putchar(char c) {
TESTING_SERIAL.print(c);
void unittest_uart_flush() {
TESTING_SERIAL.flush();
void unittest_uart_end() {
After 6.0 I had to rename the folder or file start with “test_” and need to replace unittest_transport.h with unity_config.h and unity_config.cpp according to @ivankravets .
I made the changes as below ,
unity_config.h
#ifndef UNITY_CONFIG_H
#define UNITY_CONFIG_H
#ifndef NULL
#ifndef __cplusplus
#define NULL (void*)0
#else
#define NULL 0
#ifdef __cplusplus
extern “C”
void unityOutputStart();
void unityOutputChar(char);
void unityOutputFlush();
void unityOutputComplete();
#define UNITY_OUTPUT_START() unityOutputStart()
#define UNITY_OUTPUT_CHAR(c) unityOutputChar(c)
#define UNITY_OUTPUT_FLUSH() unityOutputFlush()
#define UNITY_OUTPUT_COMPLETE() unityOutputComplete()
#ifdef __cplusplus
#endif /* extern “C” /
#endif /
UNITY_CONFIG_H */
and unity_config.cpp is ,
#include “unity_config.h”
Serial1.begin(115200);
void unityOutputChar(char c)
Serial1.print(c);
Serial1.flush();
and I’m getting the following error ,
Any idea of why this error occurs ?
Thanks,
Sam.
All you’re missing is the setUp() and tearDown() functions. Even if they are empty, they must be in the test source code.
Thank you @maxgerhardt cheers!
Hi @maxgerhardt I just add those function to my test.cpp file and it’s outputting the results now. However,
it doesn’t print any test output as what it was used to .
My test.cpp is,
#include <unity.h>
#include <ArduinoECCX08.h>
#include <utility/ECCX08JWS.h>
#include <utility/ECCX08DefaultTLSConfig.h>
TwoWire Wire2(PF0, PF1);
ECCX08Class ECCX08(Wire2, 0x60);
void setUp(void) {
// set stuff up here
void tearDown(void) {
// clean stuff up here
void test_provision()
TEST_ASSERT_MESSAGE(ECCX08.begin(), “ATECC608 not present”);
// print serial number (to be used as device ID)
String serialNum = ECCX08.serialNumber();
TEST_ASSERT_MESSAGE(serialNum && serialNum != “”, “Failed to get serial number”);
TEST_MESSAGE(String(“Device ID: M” + serialNum).c_str()); // prepend with M
bool wasLocked = ECCX08.locked();
if (!wasLocked) {
// lock device with default TLS configuration
TEST_ASSERT_MESSAGE(ECCX08.writeConfiguration(ECCX08_DEFAULT_TLS_CONFIG), “Failed to write config”);
TEST_ASSERT_MESSAGE(ECCX08.lock(), “Failed to lock ATECC608”);
String publicKeyPem = ECCX08JWS.publicKey(0, !wasLocked);
TEST_ASSERT_MESSAGE(publicKeyPem && publicKeyPem != “”, “Failed to generate/get private and/or public key”);
TEST_MESSAGE(publicKeyPem.c_str());
void setup()
delay(2000);
UNITY_BEGIN();
RUN_TEST(test_provision);
UNITY_END();
void loop()
This is the output without any message ,
Not sure I put those two functions in the right place or that causing to not to print any message ,appreciate your help .
Samson.
Thank you for your help !,cheers!
