I installed the PlatformIO IDE extension in VS Code, and I’m trying to build but keep getting errors. How do I troubleshoot this?
main.cpp
void setup() { }
void loop() { }
platformio.ini
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
I had just deleted these folders prior to the build below, as a desperate shot in the dark.
C:\Users\mmarchese\.platformio\packages
C:\Users\mmarchese\.platformio\platforms
C:\Users\mmarchese\.platformio\.cache
build output
> Executing task: C:\Users\mmarchese\.platformio\penv\Scripts\platformio.exe run <
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------Platform Manager: Installing espressif32
Platform Manager: espressif32 @ 3.5.0 has been installed!
The platform 'espressif32' has been successfully installed!
The rest of the packages will be installed later depending on your build environment.
Tool Manager: Installing platformio/toolchain-xtensa32 @ ~2.50200.0
Tool Manager: toolchain-xtensa32 @ 2.50200.97 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.10006.0
Tool Manager: framework-arduinoespressif32 @ 3.10006.210326 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.30100.0
Tool Manager: tool-esptoolpy @ 1.30100.210531 has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40300.0
Tool Manager: tool-scons @ 4.40300.1 has been installed!
PLATFORM: Espressif 32 (3.5.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Generating partitions .pio\build\esp32doit-devkit-v1\partitions.bin
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
The system cannot find the path specified.
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPv6Address.cpp.o
*** [.pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a] Error 1
*** [.pio\build\esp32doit-devkit-v1\partitions.bin] Error 1
*** [.pio\build\esp32doit-devkit-v1\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\FrameworkArduino\IPAddress.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\FrameworkArduino\IPv6Address.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\FrameworkArduino\Esp.cpp.o] Error 1
======================================================================================= [FAILED] Took 52.89 seconds ======================================================
The terminal process "C:\Users\mmarchese\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
