Can't get libraries working
Hi All,
I’m new to PlatformIO and I can’t figure out how to get libraries working. I’m working on an Arduino uno. I should mention I have a lot of industrial PLC programming/automation experience, but very little C programming or the like.
Inside PlatformIO I’ve installed the ‘max6675’ library to my project. I’ve also verified my platformio.ini has the following line:
lib_deps = MAX6675
Whenever I type #include <max6675.h> I get an error.
I feel like I’m missing something basic because I’ve had this same issue on two separate computers.
Try:
     siruli/MAX6675
The indent is one tab character, or 4 spaces when split over two lines.
There are quite a few Max6675 libraries, this link will show you them all, and each has a separate pages showing installation, examples and a list of their header files.
You are interested in those specified as being for Arduino, obviously.
HTH
Cheers,
Norm.
Hey Norman,
Thanks for the response. I added the MAX6675 library to my project via PIO Home. I’m still not having any luck. I took a screenshot of my code and my .ini file if that helps?
Ctrl+Shift+P → Rebuild Intellisense, or just press “Build” once. The library won’t be included in the IntelliSense until the intellisense is updated through a build (or manual intellisense rebuild).
Thanks for the reply. The options I saw were “PlatformIO: Build” and “PlatformIO: Rebuild IntelliSense Index”. I did both but it’s still not working.
What does “Build” result in?
Here’s the Build result
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
 - framework-arduino-avr 5.1.0
Found 6 compatible libraries
|-- <Ethernet> 2.0.0
|   |-- <SPI> 1.0
|-- <SPI> 1.0
Checking size .pio\build\uno\firmware.elf
RAM:   [          ]   4.6% (used 94 bytes from 2048 bytes)
Flash: [=         ]  10.9% (used 3530 bytes from 32256 bytes)
================================================================================================== [SUCCESS] Took 0.89 seconds ==================================================================================================
The usede libraries are Ethernet but not the Max6675 lib? Are you sure you’ve selected the correct environment via the project environment switcher in the taskbar at all?
I haven’t done anything inside the Project window. Here’s what mine looks like currently.
Click on the “env:…” in the bottom blue taskbar in VSCode and select uno in the MAX6675 project, then rebuild.
Edit: I found the environment and changed it, and it worked. Thanks so much!
