txf
June 4, 2022, 10:12am
1
I’m getting this error so I searched and found a similar problem here :
Unfortunately the solution of deleting openOCD from the packages doesn’t work. I delete it and it redownloads the packages, but the problem remains. Does anybody have a different solution?
Here is the error message.
Linking .pio\build\nucleo_wb55rg_p\firmware.elf
Checking size .pio\build\nucleo_wb55rg_p\firmware.elf
RAM: [ ] 0.4% (used 836 bytes from 196608 bytes)
Flash: [ ] 3.1% (used 16240 bytes from 524288 bytes)
AVAILABLE: blackmagic, cmsis-dap, jlink, stlink
CURRENT: upload_protocol = stlink
Uploading .pio\build\nucleo_wb55rg_p\firmware.elf
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-16-21:19)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
embedded:startup.tcl:26: Error: Can't find target/stm32w55xx.cfg
in procedure 'script'
at file "embedded:startup.tcl", line 26
Seems like a bug in platform-ststm32. The board file dictates
but looking in my C:\Users\<user>\.platformio\packages\tool-openocd\scripts\target
folder I just get
So no stm32w55xx.cfg
file. But since the chip is named wb55rg I think they meant to use stm32wbx.cfg
Please add
board_debug.openocd_target = stm32wbx
in the platformio.ini
and try debugging again. Does it change anything?
txf
June 4, 2022, 10:40am
3
in the board script there is this:
# Configuration for STM32WB55 Nucleo board (STM32WB55RGV6)
source [find interface/stlink.cfg]
transport select hla_swd
source [find target/stm32wbx.cfg]
reset_config srst_only
adding this line
Has no effect. It is still looking for the other device. It can be seen in as one of the target flags in the verbose output.
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_wb55rg_p.html
PLATFORM: ST STM32 (15.4.0) > P-Nucleo WB55RG
HARDWARE: STM32WB55RG 64MHz, 192KB RAM, 512KB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, cmsis-dap, jlink)
- framework-arduinoststm32 @ 4.20200.220530 (2.2.0)
- framework-cmsis @ 2.50700.210515 (5.7.0)
- tool-dfuutil @ 1.9.200310
- tool-openocd @ 2.1100.211028 (11.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 11 compatible libraries
No dependencies
MethodWrapper(["checkprogsize"], [".pio\build\nucleo_wb55rg_p\firmware.elf"])
.pio\build\nucleo_wb55rg_p\firmware.elf :
section size addr
.isr_vector 316 134217728
.text 14632 134218044
.rodata 1496 134232676
.ARM 8 134234172
.init_array 16 134234180
.fini_array 8 134234196
.data 112 536870916
.bss 724 536871028
.noinit 0 536871752
._user_heap_stack 1536 536871752
.ARM.attributes 48 0
.comment 102 0
.debug_frame 940 0
Total 19938
<lambda>(["upload"], [".pio\build\nucleo_wb55rg_p\firmware.elf"])
openocd -d2 -s C:\Users\Tiago\.platformio\packages\tool-openocd/scripts -f interface/stlink.cfg -c "transport select hla_swd" -f target/stm32w55xx.cfg -c "program {.pio\build\nucleo_wb55rg_p\firmware.elf} verify reset; shutdown;"
debug_level: 2
hla_swd
*** [upload] Error 1
Ohh, I see, there is a tool-openocd\scripts\board\st_nucleo_wb55.cfg
. Now that looks like a much better candidate.
Please overwrite the content of C:\Users\<user>\.platformio\platforms\ststm32\boards\nucleo_wb55rg_p.json
with
"build": {
"core": "stm32",
"cpu": "cortex-m4",
"extra_flags": "-DSTM32WB55xx",
"f_cpu": "64000000L",
"mcu": "stm32wb55rg",
"product_line": "STM32WB55xx",
"variant": "STM32WBxx/WB55R(C-E-G)V"
"connectivity": [
"bluetooth"
"debug": {
"default_tools": [
"stlink"
"openocd_board": "st_nucleo_wb55",
"jlink_device": "STM32WB55xx",
"onboard_tools": [
"stlink"
"frameworks": [
"arduino"
"name": "P-Nucleo WB55RG",
"upload": {
"maximum_ram_size": 196608,
"maximum_size": 524288,
"protocol": "stlink",
"protocols": [
"jlink",
"cmsis-dap",
"stlink",
"blackmagic"
"url": "https://www.st.com/en/evaluation-tools/p-nucleo-wb55.html",
"vendor": "ST"
And remove the previous platformio.ini
modificaiton. Does it work now?
txf
June 4, 2022, 10:52am
5
That line has to be this:
and it works!
Thanks for your help
Ah I confused board name with the actual .cfg
file, corrected now, thanks. Will PR.
