Whenever I try to build the example project for my pi pico, I get the following output, including an error about not finding nano.specs
Log:
Executing task: platformio run
Processing pico (board: pico; platform: raspberrypi; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/pico.html
PLATFORM: Raspberry Pi RP2040 (1.13.0) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 4.1.3
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 42 compatible libraries
Linking .pio/build/pico/firmware.elf
arm-none-eabi-g++: fatal error: cannot read spec file 'nano.specs': No such file or directory
compilation terminated.
*** [.pio/build/pico/firmware.elf] Error 1
======================================================================= [FAILED] Took 0.93 seconds =======================================================================
I am using VSCode on Ubuntu 24.04, and I have installed gcc-arm-none-eabi
. I’m not sure what could be the issue. My project looks the following:
src/main.cpp
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
platformio.ini
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
[env:pico]
board = pico
platform = raspberrypi
Regards,
Bruce
