Can't find ESP32-S3-WROOM-1-N16R8 (16M Flash/8SRAM)
I am new to esp32 & platformio, I bought the ESP32-S3-DevKitC-1 which has ESP32-S3-WROOM-1-N16R8(16M Flash/8SRAM), I want to create a new arduino project using platformio on vscode but I am not able to find the right board, the only one that I found is ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
Please would you help me to select the right board
The link for the Development Board
Thank you in advance
Hi, please can somebody help for this.
Thank you
You’ll want Add Espressif ESP32-S3-DevKitC-1-N16R8V board file by handledexception · Pull Request #921 · platformio/platform-espressif32 · GitHub.
I.e., copy this as boards/esp32-s3-devkitc-1-n16r8v.json file in your project and reference board = esp32-s3-devkitc-1-n16r8v in the platformio.ini. (The initial project can created with e.g. the standard ESP32-S3-DevKitC-1 board setting).
Thank you for the reply, it is working :slight_smile:
Hi, I resume this post because I have the same problem, but I’dont understand where I can put the file .json, I think in this path “.platformio\platforms\espressif32\boards” right?
Hi I to are having a problem understanding how to get the board into ‘boards’
In case you still wonder: I just had the same problem (and doubts). The boards directory is in your project directory so it worked like this:
  • create new project with board ESP32-S3-DevKitC-1
  • open terminal in project directory (where platformio.ini is)
  • call mkdir boards && wget -O boards/esp32-s3-devkitc-1-n16r8v.json https://raw.githubusercontent.com/platformio/platform-espressif32/deb6aa342245ad7bcb3d9ed69050f203779833ab/boards/esp32-s3-devkitc-1-n16r8v.json
  • update platformio.ini, as Max described
other locations of boards directories might work as well…
Cant build with that ( esp32-s3-devkitc-1-n16r8v.json ). Include arduino.h still in red. Others boards are good. Pio core 6.1.6 , Home 3.4.3
Thx for reply
same here … until I compile for the first time (i.e. until platformio downloads the needed build tools)
Still not function, Pio say me: ‘xtensa-esp32s3-elf-g++’ is not recognized as an internal or external command,
operable program or batch file.
‘xtensa-esp32s3-elf-ar’ is not recognized as an internal or external command,
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\FunctionalInterrupt.cpp.o
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\src\main.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\libFrameworkArduinoVariant.a] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\Esp.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
========================================================================== [FAILED] Took 1.34 seconds ==========================================================================
Corrupted toolchain? Delete C:\Useres\<user>\.platformio\packages\toolchain-xtensa-esp32s3 and rebuild.
I deleted folder and rebuild it and Pio said me
Processing esp32-s3-devkitc-1-n16r8v (platform: espressif32; board: esp32-s3-devkitc-1-n16r8v; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1-n16r8v.html
PLATFORM: Espressif 32 (5.0.0) > Espressif ESP32-S3-DevKitC-1-N16R8V (16 MB QD, 8MB PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
Found 32 compatible libraries
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\src\main.cpp.o
In file included from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\sys\reent.h:503,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/newlib/platform_include/sys/reent.h:17,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\stdio.h:60,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:27,
                 from src/main.cpp:1:
C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/newlib/platform_include/assert.h:20:10: fatal error: sdkconfig.h:
No such file or directory
* Looking for sdkconfig.h dependency? Check our library registry!
* CLI  > platformio lib search "header:sdkconfig.h"
* Web  > https://registry.platformio.org/search?q=header:sdkconfig.h
 #include <sdkconfig.h>
compilation terminated.
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\IPv6Address.cpp.o
In file included from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/FirmwareMSC.h:17,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/FirmwareMSC.cpp:14:
C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/USBMSC.h:18:10: fatal error: sdkconfig.h: No such file or directory
 #include "sdkconfig.h"
In file included from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/HWCDC.cpp:14:
C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/USB.h:16:10: fatal error: sdkconfig.h: No such file or directory
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\FirmwareMSC.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\HWCDC.cpp.o] Error 1
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/Esp.cpp:20:
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.cpp:20:
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\stdlib.h:18,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\cstdlib:75,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\stdlib.h:36,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.cpp:1:
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPv6Address.cpp:20:
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\IPAddress.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\IPv6Address.cpp.o] Error 1
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\wchar.h:6,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\cwchar:44,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\bits\postypes.h:40,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\bits\char_traits.h:40,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\string:40,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\stdexcept:39,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\array:39,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\tuple:39,
                 from c:\users\jana\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\functional:54,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/FunctionalInterrupt.h:11,
                 from C:/Users/Jana/.platformio/packages/framework-arduinoespressif32/cores/esp32/FunctionalInterrupt.cpp:8:
=============================================================== [FAILED] Took 10.50 seconds ===============================================================
Seem slike your framework download is incomplete too. Delete this folder fully and rebuild.
I deleted this folder and download and unpack it, but my problem is still the same. I make new project only with this board and build it.
----------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20003.0
Downloading  [####################################]  100%
Unpacking  [####################################]  100%
Tool Manager: framework-arduinoespressif32@3.20003.220626 has been installed!
          ^~~~~~~~~~~~Compiling .pio\build\esp32-s3-devkitc-1-n16r8v\FrameworkArduino\IPv6Address.cpp.o
===================================================== [FAILED] Took 346.49 seconds =====================================================
  1. Close VSCode
  2. Delete the folder C:/Users/Jana/.platformio/ fully
  3. Reopen VSCode
  4. Wait until PlatformIO has reinstalled itself and the packages automatically
  5. Build again.
Thansk for solution. My steps:
  1. close VSCode
  2. Delete folder .platformio
  3. open VSCode
  4. Wait until PIO reinstaled
  5. Click build then PIO say me DONT know the board
  6. i copy board.json from web to C:\Users\Jana.platformio\platforms\espressif32\boards.platformio
  7. Click build again and build was succesfull (when see bottlom line red #include <Arduino.h> ) restart VSCode
