Hi Everyone, I am having trouble starting a debug session with my esp32 wroom and the esp-prog. The hash keeps failing to verify for some reason. I see errors about flash maps.
undefinedC:\Users\Starfox64\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from C:\Users\Starfox64\Desktop\Projects\Rocket\Rocket_Controller_ESP_32\Rocket_Controller_Easy_mode\.pio\build\upesy_wroom\firmware.elf...
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 5000 kHz
Info : starting gdb server for esp32.cpu0 on pipe
Info : [esp32.cpu0] Target halted, PC=0x40107C36, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : [esp32.cpu1] Target halted, PC=0x4008AFCE, debug_reason=00000000
Warn : No symbols for FreeRTOS!
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
Error: Failed to get flash maps (4294967290)!
Warn : Failed to get flash mappings (-4)!
2
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 0 KB
Info : Using flash bank 'esp32.cpu0.drom' size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x40107c36 in esp_pm_impl_waiti () at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal/esp32/include/hal/cpu_ll.h:183
183 /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal/esp32/include/hal/cpu_ll.h: No such file or directory.
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x4008B948, debug_reason=00000000
Info : [esp32.cpu1] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu1] Core was reset.
Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Erased 20480 bytes in 362.832 ms
Info : PROF: Data transferred in 108.026 ms @ 185.141 KB/s
Info : PROF: Wrote 20480 bytes in 419.161 ms (data transfer time included)
** Programming Finished in 1460 ms **
** Verify Started **
Info : PROF: Flash verified in 109.032 ms
Error: **** Verification failure! ****
Error: target_hash 58cd6d...6a3d7b
Error: file_hash: 3d97b7...e46563
** Verify Failed **
.pioinit:12: Error in sourced command file:
Protocol error with Rcmd
