I’m trying to use the debugger in VS code platfornio on the ESP32-Ethernet-Kit v1.2 but I’m getting “Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED”.
I using WinUSB on Interface 0 and FTDIBUS on Interface 1
dip switch is by default on
Platformio.ini:
[env:wt32-eth01]
board = esp-wrover-kit
framework = espidf
upload_speed = 115200
upload_port = COM4
monitor_port = COM4
debug_tool = ftdi
debug_init_break = tbreak app_main
Full Error:
Warning: 'set target-async', an alias for the command 'set mi-async', is deprecated.
Use 'set mi-async'.
PlatformIO: debug_tool = ftdi
Warning: 'flushregs', an alias for the command 'maintenance flush register-cache', is deprecated.
Use 'maintenance flush register-cache'.
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : starting gdb server for esp32.cpu0 on pipe
Error: timed out while waiting for target halted
Error executing event gdb-attach on target esp32.cpu0:
Warn : No symbols for FreeRTOS!
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Remote communication error. Target disconnected.: No error.
Sorry if I have missed anything obvious.
Many thanks.
