The target system is: Generic - -
The host system is: Windows - 10.0.18363 - AMD64
Compiling the C compiler identification source file “CMakeCCompilerId.c” succeeded.
Compiler: C:/Users/hones/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe
Build flags: -mlongcalls;-Wno-frame-address
Id flags:
The output was:
0
Compilation of the C compiler identification source “CMakeCCompilerId.c” produced “a.out”
The C compiler identification is GNU, found in “PROJECTDIR/.pio/build/esp32cam/CMakeFiles/3.16.4/CompilerIdC/a.out”
Compiling the CXX compiler identification source file “CMakeCXXCompilerId.cpp” succeeded.
Compiler: C:/Users/hones/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-g++.exe
Id flags:
The output was:
0
Compilation of the CXX compiler identification source “CMakeCXXCompilerId.cpp” produced “a.out”
The CXX compiler identification is GNU, found in “PROJECTDIR/.pio/build/esp32cam/CMakeFiles/3.16.4/CompilerIdCXX/a.out”
Checking whether the ASM compiler is GNU using “–version” matched “(GNU assembler)|(GCC)|(Free Software Foundation)”:
xtensa-esp32-elf-gcc.exe (crosstool-NG esp-2020r2) 8.2.0
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Determining if the C compiler works passed with the following output:
Change Dir: PROJECTDIR/.pio/build/esp32cam/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Users/hones/.platformio/packages/tool-ninja/ninja.exe cmTC_aff08 && [1/2] Building C object CMakeFiles/cmTC_aff08.dir/testCCompiler.c.obj
[2/2] Linking C executable cmTC_aff08
c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: warning: cannot find entry symbol _start; defaulting to 0000000000400054
Detecting C compiler ABI info compiled with the following output:
Run Build Command(s):C:/Users/hones/.platformio/packages/tool-ninja/ninja.exe cmTC_b7d57 && [1/2] Building C object CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj
Using built-in specs.
COLLECT_GCC=C:\Users\hones.platformio\packages\toolchain-xtensa32\bin\xtensa-esp32-elf-gcc.exe
Target: xtensa-esp32-elf
Configured with: /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/gcc/configure --build=x86_64-build_pc-linux-gnu --host=x86_64-host_w64-mingw32 --target=xtensa-esp32-elf --prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf --with-headers=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/include --with-newlib --enable-threads=no --disable-shared --with-pkgversion=‘crosstool-NG esp-2020r2’ --disable-__cxa_atexit --enable-cxx-flags=-ffunction-sections --disable-libgomp --disable-libmudflap --disable-libmpx --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpfr=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpc=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-isl=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --enable-lto --enable-target-optspace --without-long-double-128 --disable-nls --enable-multiarch --enable-languages=c,c++ --disable-libstdcxx-verbose --enable-threads=posix --enable-gcov-custom-rtio --enable-libstdcxx-time=yes
Thread model: posix
gcc version 8.2.0 (crosstool-NG esp-2020r2)
COLLECT_GCC_OPTIONS=‘-mlongcalls’ ‘-Wno-frame-address’ ‘-v’ ‘-o’ ‘CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj’ ‘-c’
c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/cc1.exe -quiet -v -iprefix c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/ C:/Users/hones/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mlongcalls -auxbase-strip CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj -Wno-frame-address -version -o C:\Users\hones\AppData\Local\Temp\ccMZMAkB.s
GNU C17 (crosstool-NG esp-2020r2) version 8.2.0 (xtensa-esp32-elf)
compiled by GNU C version 6.3.0 20170516, GMP version 6.1.2, MPFR version 4.0.1, MPC version 1.1.0, isl version isl-0.19-GMP
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/include”
ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed”
ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include”
ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include”
#include “…” search starts here:
#include <…> search starts here:
c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/include
c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed
c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include
c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include
End of search list.
Compiler executable checksum: d98399b385b6803868acbf63bf04c6aa
c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/as.exe --traditional-format --longcalls -o CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj C:\Users\hones\AppData\Local\Temp\ccMZMAkB.s
COMPILER_PATH=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/;c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/;c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/
LIBRARY_PATH=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/;c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/;c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib/
[2/2] Linking C executable cmTC_b7d57
COLLECT_LTO_WRAPPER=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper.exe
Thread model: posix
COLLECT_GCC_OPTIONS=‘-mlongcalls’ ‘-Wno-frame-address’ ‘-nostdlib’ ‘-v’ ‘-o’ ‘cmTC_b7d57’
c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/collect2.exe -plugin c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/liblto_plugin-0.dll -plugin-opt=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper.exe -plugin-opt=-fresolution=C:\Users\hones\AppData\Local\Temp\cc4wIW9F.res -o cmTC_b7d57 -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0 -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj
Parsed C implicit include dir info from above output: rv=done
found start of include info
found start of implicit include info
add: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/include]
add: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed]
add: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include]
add: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include]
end of search list found
collapse include dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/include] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0/include]
collapse include dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed]
collapse include dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/sys-include]
collapse include dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include]
implicit include dirs: [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0/include;C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed;C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/sys-include;C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include]
Parsed C implicit link information from above output:
link line regex: [^( |.[/])(xtensa-esp32-elf-ld.exe|CMAKE_LINK_STARTFILE-NOTFOUND|([^/]±)?ld|collect2)[^/]*( |$)]
ignore line: [Change Dir: PROJECTDIR/.pio/build/esp32cam/CMakeFiles/CMakeTmp]
ignore line:
ignore line: [Run Build Command(s):C:/Users/hones/.platformio/packages/tool-ninja/ninja.exe cmTC_b7d57 && [1/2] Building C object CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=C:\Users\hones.platformio\packages\toolchain-xtensa32\bin\xtensa-esp32-elf-gcc.exe]
ignore line: [Target: xtensa-esp32-elf]
ignore line: [Configured with: /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/gcc/configure --build=x86_64-build_pc-linux-gnu --host=x86_64-host_w64-mingw32 --target=xtensa-esp32-elf --prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf --with-headers=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/include --with-newlib --enable-threads=no --disable-shared --with-pkgversion=‘crosstool-NG esp-2020r2’ --disable-__cxa_atexit --enable-cxx-flags=-ffunction-sections --disable-libgomp --disable-libmudflap --disable-libmpx --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpfr=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpc=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-isl=/builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --enable-lto --enable-target-optspace --without-long-double-128 --disable-nls --enable-multiarch --enable-languages=c c++ --disable-libstdcxx-verbose --enable-threads=posix --enable-gcov-custom-rtio --enable-libstdcxx-time=yes]
ignore line: [Thread model: posix]
ignore line: [gcc version 8.2.0 (crosstool-NG esp-2020r2) ]
ignore line: [COLLECT_GCC_OPTIONS=‘-mlongcalls’ ‘-Wno-frame-address’ ‘-v’ ‘-o’ ‘CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj’ ‘-c’]
ignore line: [ c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/cc1.exe -quiet -v -iprefix c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/ C:/Users/hones/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mlongcalls -auxbase-strip CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj -Wno-frame-address -version -o C:\Users\hones\AppData\Local\Temp\ccMZMAkB.s]
ignore line: [GNU C17 (crosstool-NG esp-2020r2) version 8.2.0 (xtensa-esp32-elf)]
ignore line: [ compiled by GNU C version 6.3.0 20170516 GMP version 6.1.2 MPFR version 4.0.1 MPC version 1.1.0 isl version isl-0.19-GMP]
ignore line:
ignore line: [GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072]
ignore line: [ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/include”]
ignore line: [ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed”]
ignore line: [ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include”]
ignore line: [ignoring duplicate directory “c:/users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/…/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include”]
ignore line: [#include “…” search starts here:]
ignore line: [#include <…> search starts here:]
ignore line: [ c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/include]
ignore line: [ c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/include-fixed]
ignore line: [ c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/sys-include]
ignore line: [ c:\users\hones.platformio\packages\toolchain-xtensa32\bin../lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/include]
ignore line: [End of search list.]
ignore line:
ignore line: [Compiler executable checksum: d98399b385b6803868acbf63bf04c6aa]
ignore line: [ c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/as.exe --traditional-format --longcalls -o CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj C:\Users\hones\AppData\Local\Temp\ccMZMAkB.s]
ignore line: [COMPILER_PATH=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/]
ignore line: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/]
ignore line: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/]
ignore line: [LIBRARY_PATH=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/]
ignore line: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/]
ignore line: [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib/]
ignore line: [[2/2] Linking C executable cmTC_b7d57]
ignore line: [COLLECT_LTO_WRAPPER=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper.exe]
ignore line: [COLLECT_GCC_OPTIONS=‘-mlongcalls’ ‘-Wno-frame-address’ ‘-nostdlib’ ‘-v’ ‘-o’ ‘cmTC_b7d57’]
link line: [ c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/collect2.exe -plugin c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/liblto_plugin-0.dll -plugin-opt=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper.exe -plugin-opt=-fresolution=C:\Users\hones\AppData\Local\Temp\cc4wIW9F.res -o cmTC_b7d57 -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0 -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc -Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj]
arg [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/collect2.exe] ==> ignore
arg [-plugin] ==> ignore
arg [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/liblto_plugin-0.dll] ==> ignore
arg [-plugin-opt=c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper.exe] ==> ignore
arg [-plugin-opt=-fresolution=C:\Users\hones\AppData\Local\Temp\cc4wIW9F.res] ==> ignore
arg [-o] ==> ignore
arg [cmTC_b7d57] ==> ignore
arg [-Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0] ==> dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0]
arg [-Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc] ==> dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc]
arg [-Lc:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib] ==> dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib]
arg [CMakeFiles/cmTC_b7d57.dir/CMakeCCompilerABI.c.obj] ==> ignore
collapse library dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0]
collapse library dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc]
collapse library dir [c:/users/hones/.platformio/packages/toolchain-xtensa32/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/lib] ==> [C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/lib]
implicit libs:
implicit dirs: [C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc/xtensa-esp32-elf/8.2.0;C:/Users/hones/.platformio/packages/toolchain-xtensa32/lib/gcc;C:/Users/hones/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/lib]
implicit fwks:
Determining if the CXX compiler works passed with the following output:
Run Build Command(s):C:/Users/hones/.platformio/packages/tool-ninja/ninja.exe cmTC_3693f && [1/2] Building CXX object CMakeFiles/cmTC_3693f.dir/testCXXCompiler.cxx.obj
[2/2] Linking CXX executable cmTC_3693f
