I want to implement code using the TextLCD library from Mbed, I already tested in mbed online platform and it works as expected, but I can’t get it properly to work here in platformio, I installed using this steps
but I only get errors during the compilation. First there was an error:
expected class-name before ‘{’ token platformio
in class TextLCD_Base : public Stream {
(this does not happen in the mbed online ide).
I decided to #include “Stream.h”
and now I got
In file included from src\main.cpp:2:
C:/Users/AIOTIK-005/.platformio/lib/TextLCD/TextLCD.h:765:20: error: expected ‘)’ before ‘*’ token
765 | TextLCD_I2C(I2C *i2c, char deviceAddress = PCF8574_SA0, LCDType type = LCD16x2, LCDCtrl ctrl = HD44780);
C:/Users/AIOTIK-005/.platformio/lib/TextLCD/TextLCD.h:819:5: error: ‘I2C’ does not name a type; did you mean ‘I2C1’?
819 | I2C *_i2c;
| I2C1
What could be the issue?
my code is simply including the library into main.cpp. so it is pretty a default program to start testing in platformio.
Thanks!
