Hi there! I’m trying to compile an example project for my ESP8266 ESP01 board. I have my project considered like so:
[env:latest_stable]
platform = espressif8266
board_build.f_cpu = 80000000L
board_build.f_flash = 80000000L
board_build.flash_mode = qio
upload_resetmethod = ck
upload_speed = 9600
board = esp01
However, when I try to build it I get the following error:
pio run --target upload --target monitor
Processing latest_stable (platform: espressif8266; board: esp01)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01.html
PLATFORM: Espressif 8266 2.4.0 > Espressif Generic ESP8266 ESP-01 512k
HARDWARE: ESP8266 80MHz, 80KB RAM, 512KB Flash
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 1.40802.0 (4.8.2)
Found 0 compatible libraries
AttributeError: 'SConsEnvironment' object has no attribute 'ElfToBin':
File "/home/andrew/.local/lib/python2.7/site-packages/platformio/builder/main.py", line 156:
File "/home/andrew/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 541:
File "/home/andrew/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "/home/andrew/.platformio/platforms/espressif8266/builder/main.py", line 218:
target_firm = env.ElfToBin(
I can build for a different platform (Kendryte k210) just fine, so I know that my platformio install isn’t completely broken. I’m on version 4.3.1, and I’ve recently run platformio platform update
, so I should be fine in that regard.
Has anybody seen this before? I’d appreciate any help in getting this fixed.
Thanks!
